Sziasztok. A cimbeli erositovel szenvedek. Hibasan vettem, csak az egyik bemenetrol mukodott. Mikor levettem a tetejet, lattam, hogy a bementvalaszto ic at van kotve. Rendeltem egy masikat, de ez sem akar mukodni. Mintha teljesen halott lenne, nem megy at a jel rajta - nincs egy bemenet sem kivalasztva. +- tapfeszek megvannak, a kapcsolat a kontrollerrel pin to pin leellenorizve. Nincs tobb otletem, szerintem 2 lehetoseg maradt: vagy a bementvalaszto ic halott, vagy a kontroller, bar a kivalasztott bemenetnek megfelelo ledek kigyulnak. Volt valakinek hasonlo esete?
Van egy Onkyo TX-NR509 erősítő. A hiba jelenség: bekapcsolásnál a Check SP Wire hibaüzenet jelenik meg, szinte egy pillanatig, majd utána kikapcsol. Kérnék egy kis segítséget a hiba behatárolásához.
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Adott acímben szereplő házimozi erősítő amiben tönkre ment egy pár alkatrész.Ezek közül a 2sb1369-et nem kapok a hq elektronikánál (onnan szoktam rendelni). Abban kérem a helpet hogy ezt honnan tudnám beszerezni (nem horror áron), vagy ha van helyettesítője akkor annak típusát megköszönném. Találtam egy 2sb1370-et. Az adatok szerint ez is jó lehet...vagy nem?
Kicseréltem a meghatókat az MJE340/MJE350 párosra, a véget 2SC5200/2SA1943 párosra és még 2db 10A-es bizti aztán indult is. Mindenkinek nagyon köszönöm a segítséget!
Szép napot!
