Download free of charge (10 files / day): Download processing...
Also known:
PANASONIC PANASDS-15 PANASDS15 PANASDS 15
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
Hello everyone, I'm having issues fixing this vintage stereo system, its amplifier boards seems to not be amplifying. The audio comes out at super low volume with the max. volume setting (the pot. works correctly). At first I had 20V and a constant hum coming out at the speakers output (saturated amp. I supossed). I changed the electrolytic caps., the 5218P component (TL082 replacement) and the NPN/PNP C1815 and A1015 transistors (this last thing helped with the amp. saturation and I do not have any DC at speakers now), but now the audio comes out super low. I measured the D1265 transistors off-board and they seem to be ok. Can anyone shed some light? Thanks in advance
Menet közben némult el, lement készenlétbe azóta nem indul, gombnyomásra kattan a relé, aztán vissza le, más életjelet nem ad, tegnap este belenéztem, szerintem a trafója adta fel a harcot.Valamelyikőtök találkozott eme hibával?
Van 1 Panasonic CQ-RDP113 (nem mp3-as) típusú autórádióm, szépen működött, egyszer csak azt csinálta, hogy kikapcsol.Volt amikor még be tudtam kapcsolni, de most már semmi...
Bekapcsoláskor villan 2-t a power ledje, de nem csinál semmit.Mi lehet a baja? A végfok IC-t kiszedtem belőle(arra gyanakodtam), amiatt tilt le, de nem segített!
Később jutott eszembe, hogz megnézem az adatlapját, nincs tiltási lehetősége...
Tudna valaki segíteni?
Esetleg 1 rajz???
Előre is KÖSZI!
A fenti erősítő csoda rajzát keresem ha valakinek megvolna nagyon megköszönném.
Az élet furcsasága, hogy egy hete az utódját sax710 javítottam. Itt kaptam tanácsot és teljes a siker. Köszönet a jó csapatnak !
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
