If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
Hali.Kis segitséget kérnék egy dioda azonositásban a pozició szám:d509 zárlatos lett,s f61 hibakódot ir ki.A diodán amenyire kiolvastam b10 vagy valami ilyesmit ir(nem biztos).Sm et vettem le a netröl de nem egyezik vele.Ha valaki tudja kérem segitsen Üdv
Menet közben némult el, lement készenlétbe azóta nem indul, gombnyomásra kattan a relé, aztán vissza le, más életjelet nem ad, tegnap este belenéztem, szerintem a trafója adta fel a harcot.Valamelyikőtök találkozott eme hibával?
Hello everyone, I'm having issues fixing this vintage stereo system, its amplifier boards seems to not be amplifying. The audio comes out at super low volume with the max. volume setting (the pot. works correctly). At first I had 20V and a constant hum coming out at the speakers output (saturated amp. I supossed). I changed the electrolytic caps., the 5218P component (TL082 replacement) and the NPN/PNP C1815 and A1015 transistors (this last thing helped with the amp. saturation and I do not have any DC at speakers now), but now the audio comes out super low. I measured the D1265 transistors off-board and they seem to be ok. Can anyone shed some light? Thanks in advance
Van egy Panasonic SA-HE90 házimozierősítőm, ami bekapcsoláskor "Overload" hibaüzenettel indul és kéri a kikapcsolását. A relék nem kattannak.
A gép közel 20 éves, eddig gyönyörűen működött, ugyanezekkel a hangfalakkal, nem történt változás ezen a téren.
Az eredeti hibája az volt, hogy a Front A bal csatorna elkezdett vacakolni, azaz halkan nem szólt, csak ha már jócskán feltekertem a hangerőt és akkor is csak hangos részletekkor, a halkak mint egy zajzár esetén elvesztek. Gondoltam valami kiszáradt vacak forrasztás lehet az oka, így szétszedtem és azokon a helyeken, ahol csúnyább volt vagy láthatóan nagyon spóroltak az ónnal, felfrissítettem a forrasztásokat. Nem ma kezdtem a forrasztással foglalkozást, szóval nem elgányoltam, hanem szépen kiszippantottam kiforrasztópisztollyal és friss ónnal pótoltam a forrasztásokat.
Összerakás után csak az Overload jelenik meg 2-3 mp után és nem kattannak a relék.
Bármilyen ötletért akár az overload-ra, akár az eredeti problémára hálás lennék.
Ha valaki foglalkozik ezzel a szériával Esztergom környékén, szívesen átadnám a problémát. Nem értek az erősítőkhöz ilyen mélységekben, de nagyon szeretem ezt a darabot :)
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
