PHILIPS FC6145-01 VACUUM CLEANER
HOOVER - SERVICE MANUAL
208.2 KB
HOOVER
PHILIPS FC6145-01 VACUUM CLEANER service manual (1st page)
Preview of PHILIPS FC6145-01 VACUUM CLEANER [1st page]
PHILIPS FC6145-01 VACUUM CLEANER service manual (2nd page)
Preview of PHILIPS FC6145-01 VACUUM CLEANER [2nd page]
    PHILIPS FC-614501 CLEANER FC614501 VACUUM FC 614501 FC6145 01 FC6145-01
Relevant HOOVER forum topics:
Philips XSmall HD8743 kávéfőző nehezen "kapja fel a vizet"
Címben említett automata főzőnek egy ideje bekapcsoláskor elvileg öblítenie kéne a vízkörét; de csak nehezen, vagy sehogy sem tudja felvenni a vízet a tartályból. Eddig amit láttam hasonló főzőnél videót: a pumpa vagy egy úgynevezett túlnyomás szelep elöregedése volt az ok. Honnan induljak, mit ellenőrizzek le a készülékben? Javítható-e a hiba gazdaságosan?
Philips GC 4630 vasaló nem melegít (megoldva)
A másik....
Relé kocogtatásra indul, tehát a relé rossz.
De ez meg ki van öntve, köszönjük szépen :(
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips HI5916 gőzölős vasaló csipogó hangjelzést ad !
Sziasztok ! Már korábban szó volt a  vaslóról , sikerült vezérlő panelt beszerezni ! látszólag működik olyannyira  hogy állandóan  fűtene  minek következtében a hőbizti megadta  magát ! A készülékben  van még egy panel ami tápokat állít elő a procinak és 24 V ot a rellé meghúzásához ami a fütőszálat kapcsolja , nos ennek a panelnak a rajzát  keresem hogy tovább tudjak lépni   van egy pár SMD tranyó rajta vagy dióda talán rajz alapján lehetne eldönteni ! A hőfokszabályozó poti és termisztor ami a vezérlő panelhez csatlakozik rendben a hőbiti átkötve ideiglenesen a hiba behatárolása véget ! Várnám ötleteiteket ! Üdv!
