PHILIPS HD1123 SM
HOUSEHOLD - SERVICE MANUAL
445.9 KB
HOUSEHOLD
PHILIPS HD1123 SM service manual (1st page)
Preview of PHILIPS HD1123 SM [1st page]
PHILIPS HD1123 SM service manual (2nd page)
Preview of PHILIPS HD1123 SM [2nd page]
    PHILIPS HD-1123 HD1123 HD 1123
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
PHILIPS HR1365 600W Botmixer szétszedése - Megoldva! -
Üdvözletem, sziasztok! Adott egy 600W-os PHILIPS botmixer. A 2 év garancia 1 hónapja járt le, a gép egyik nyomógomra sem reagál, nem indul a motorja. Alig volt használva, teljesen újszerű az állapota. Az alsó két ledugózott csavart megtaláltam, de a ráragasztott(?) gumi borítások alatt nincs észlelhető nyoma a csavaroknak. Mi a trükkje a szétszedésnek jelentős roncsolás nélkül? Szedett már szét ilyen masinát valaki? A kérdéses mixer alapgépe a képen látható, de 230V-os kiadásban. További szép napot! Üdv: Sándor
Philips FC6171/01/F/A akku hiba
Az összes ilyen gép ennyire hulladék, hogy három évesen mehetnek a szemétbe?
Fél percet sem bír az akku benne. Van valami módszer ezen akkuk javítására vagy ezek kukák?
Illetve a bajom, hogy 50000 lenne a csere, mivel valószínűleg elektronikával együtt lehet cserélni. Új aksikkal is tiltani fog az elektronika.
Csak 28000 most nézem :D
https://www.intercell.hu/philips_powerpro_duoa_fc6171_series_252v_2000mah_5040wh_li-ion_porszivo_akkuakkumulator_129793?utm_source=google_shopping&utm_medium=cpp&utm_campaign=direct_link&gQT=2
Philips GC576/60/BC-NL 9206 AD-4 gozallomas zarlata-Hiba nem jelentkezett
A gozallomas a tulaj elmondasa szerint  " leveri a villanyt " Ehhez kerem a segitsegeteket amit elore is koszonok Udv
