PHILIPS HD7812-63E COFFEE MAKER SENSEO
COFFEE-MACHINE - SERVICE MANUAL
407.5 KB
COFFEE-MACHINE
PHILIPS HD7812-63E COFFEE MAKER SENSEO service manual (1st page)
Preview of PHILIPS HD7812-63E COFFEE MAKER SENSEO [1st page]
PHILIPS HD7812-63E COFFEE MAKER SENSEO service manual (2nd page)
Preview of PHILIPS HD7812-63E COFFEE MAKER SENSEO [2nd page]
    PHILIPS HD-781263E COFFEE MAKER SENSEO HD781263E HD 781263 HD7812 63E HD7812-63E
Relevant COFFEE-MACHINE forum topics:
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips HD8651 kilöki a nyomóegységet.
Sziasztok Kollégák!
A fent említett kávégép felfűt!
A kávé gomb lenyomása után kilöki a nyomóegység alsó részét és leáll.A felső részén lévő retesz nem old ki.
A benne lévő nyomóegységet valaki alaposan bekente valami gépzsírral.Ezt eltávolítottam és újra zsíroztam,normálisan,de a hiba ugyanúgy fenn áll.
Más nyomóegységgel működik.
Van valakinek valami ötlete.
Köszönöm a megtisztelő figyelmet és az építő ötleteket.
Üdv Tomi
Philips HD5730 kávégép vizkövezése, tejtartó nélkül.Hogyan? Újabb gondok !
Szép napot ! A fent említett kéri a vízkő eltávolító programot. Viszont a tejtartó hiányában a program nem indul. Hiányolja, az ebben profik véleményét kérdem, hogyan lehet egyszerűen megoldani a gondot. Mivel a tejtartóhoz tartozó " csonkok " is hiányoznak. Amik a programhoz tartozó mikrokapcsolókat, kacsolnák. Tudom legegyszerűbb lenne venni hozzá, tartály van is, potom 10 ezerért de tető nincs. A lényeg pedig az lenne. Köszönöm a figyelmet !
Philips Whirlpool M606 mikró üresen ment, szikrázott, füstölt
Véletlenül üresen ment a gép elég hosszan, szikrázás, füst és a jelek szerint mintha "izzás" is történt volna mire észrevették.
A nagy képen pirossal bekeretezve keretben a Égett belső.jpg-n látható rész. Középen függőleges csíkban kormos lett az belső oldal, azt lemosták, ez már a tisztított állapot.
A gép maga működik, melegíti a vizet.
Mi lehet ez az égés, melyik oldalról indult? Lehet hogy a másik oldalról égett át?
Az a leszegecselt kis ablak mit takar?
És persze, hogy használható-e tovább biztonsággal?
Más sérülést nem fedeztek fel rajta, az ajtó rácsa is ép.
