PIONEER CLD-D703 D503 D770 D570 S360 RRV1066
VIDEO-DVD - SERVICE MANUAL
1.8 MB
PIONEER CLD-D703 D503 D770 D570 S360 RRV1066 service manual (1st page)
Preview of PIONEER CLD-D703 D503 D770 D570 S360 RRV1066 [1st page]
PIONEER CLD-D703 D503 D770 D570 S360 RRV1066 service manual (2nd page)
Preview of PIONEER CLD-D703 D503 D770 D570 S360 RRV1066 [2nd page]
    PIONEER CLDD-703 CLDD703 D503 D770 D570 S360 RRV1066 CLDD 703 503 770 570 360 RRV 1066 CLD D703 CLD-D703
Panasonic befűző mechnaika fogaskerék megjött : )
Sziasztok! Ígértem, hogy szólok, hát szólok. Megjött a fogaskerék :) Ez maga a fogaskerék, a fémről le kell szedni a régit és ezt rárakni. Üdv: Pityesz
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
JVC HR-J200EE(S) és Akai VS-465EDG alkatrészek
Sziasztok! Hiányosak, tetejük sincs, stb. Akinek valami kell belőle szóljon, holnap bontom, kazettafészek is megvan holnapig :) Üdv: Pityesz
[ELKELT]Kb 40 db videomagnó elvihető
Sziasztok! Kicsit összébb kell húznom magam, ezért pár dolgot elajándékoznék. Aki viszi, az egyben vigye az egészet, mert nem tudom pakolgatni. A műhelyem költözik, így csak egyszer bányászom elő a cuccot. Kb 40 video, pár beltéri. A beltérik akár jók is lehetnek, de öregek. A videomagnók állapotára már nem emlékszem, pár darabot megbontottam annak idején. Ja a lényeg: SÜRGŐS. Üdv Dénes Károly.
