Egy barátom megkért h chippeljem meg a kisfia konzolját, körbe néztem a neten lehet találni egy rakat leírást,
de nem tudom eldönteni h melyik mellett tegyem le a voksom.
Szerintetek melyik lenne a legjobb választás?
Tudom h ez nem legális dolog ezért csak is kivételes eset ez.
Ha valaki tud nekem "hiteles" adatokat a bekötéséről és a chip típusról akkor szívesen venném a segítségét.
Köszi előre is mindenkinek!
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Hello! Adott egy RGB64 LED par lámpa, azaz 64 LED van benne 3 színre osztva. A tápja (nem trafós) sípol akkor is, ha a LED-ek le vannak róla húzva (és csak az elektronika dolgozik), rádugva pedig színenként más hanggal sípol-zizeg. 12,13V-12,15V a kimenetén minden szín esetében megvan, tehát a hangjától eltekintve jól működik, viszont ha ez egy fázison van egy digitális (SPDIF) átvitelt használó eszközzel, akkor a másik eszköz időnként 1-1mp-ig elveszíti a jelet (rövid (1m), minőségi gyári SPDIF kábel ellenére is) random időközönkét, tehát nem folyamatosan (mint amikor egy másik nagyobb fogyasztó kapcsol be mellette). Gondolom, hogy kondi fáradás okozhatja a hibát, de az elkók ránézésre nem püffedtek. Egyenként kéne végigmérni az összes kondit (nem csak elkót), vagy máshol lesz a hiba? Illetve ebben az állapotában még meddig életképes a táp, mikor fog eldurranni?
Üdv mindenkinek
Kérdezném tisztelettel, látott-e már valaki ilyen ledszalaghoz való kínai tápot, (model 12020, 12v, 2A), és meg tudná-e mondani milyen ic van benne, mert ezen az ic-n nyoma sincs írásnak. Csak nem műkszik, ennyi a baja, passzív elemek vizsgálva, puffer száraz volt, cserélve, egy 1Mohm-os ellenállat 3-ra nyúlva, cserélve, optocsatoló jó, és megáll a tudomány információ hiányában.
Kösz: Csaba
