RUSSIAN STRELA-PRIEMNIK RADIO-GRAMO SCH
Type: (GIF)
104.2 KB
Looking for similar russian manual?
    RUSSIAN RADIOGRAMO STRELA PRIEMNIK RADIO GRAMO
Denon PMA500V amplifier
I have and found most of the voltages as indicated on the circuit diagram, till op amp M 5218P; are near those specifed. The output on the centre of the two power transistors of both the channels are also alright.
While looking at the voltages on test points as mentioned on the page 7 for setting up quiscent current, these cannot be set.
Bit of history,  the amplifier was lying unused for long time. Nothing in it has burnt. It was never opened earlier than this time, couple of days back.
While I was probing for voltages with DMM, with probe on collector of TR413 one of the fuses blew up. Later same thing happened on the other channel as well.
With the above as background can a Good Samaritan  figure out feasibility of repair.
i am unable to upload service manual as file size is 7.3 mb
Kenwood KRF - V7070D hifi erősítő
Sziasztok! Adva van a címben szereplő eszköz, a hiba a következő, minden működik normálisan de egy idő után leáll. Szemre a puffer kicsit mintha puffadt lenne de ez nem 100%. Ez okozhat leállást? Szóval KENWOOD KRF-V7070D a kicsike....
Mackie SRM 450 needs help
i have an speaker mackie srm450 the problem is need a lot of signal for start to work i don't now why? i all ready checked all the input and routing an looks fine tried to upload the schematic but i can not do
SONY STR-DH130 Rádió-erősitőhöz TÁVIRÁNYITÓT keresek
Keresek távirányitót országunkon belül a cimbeli készülékhez. Megfelel az utángyártott tipus is. Tipusa: RM-AAU130
Találtam megfelelő tipust, de nem válaszolnak a megkeresésemre. Sony RM-AAU168 távirányító utángyártott (Original Quality) (eurobeat.hu)
A cégről esetleg tud valaki információt adni?
Köszönöm
