SCHAUB BETA-KRAFT-W 1930 SCH
750.4 KB
Looking for similar schaub manual?
    SCHAUB BETAKRAFTW 1930 BETA KRAFT
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
BECKER AVUS BE2035 kod
Sziasztok! A fenti autórádióval az a gondom, hogy kéri a kódot. Azonban ez még nem is lenne gond, mert meg van a kódja, de nem vagyok elég gyors a beírásához. Ugyanis az ON-gomb megnyomása után vagy két másodperc elteltével kiírja hogy "CODE", meg az lcd-n 1-től 0-ig a tíz gomb felírata, majd kb 3-5 mp múlva kikapcsol magától a készülék és abszolúte nem érdekli, hogy én mit szeretnék. Hiába próbálom gyorsan benyomogatni a kódot, arra sem reagál. Mitévő legyek? Nem kéne eldobni, ugy gondolom. Köszi! Üdv! Imre
JVC DX-MX77TN HI-FI Nem ad hangot. A bemeneti szelektor áramkör nem kapcsol át.
Kedves kollégák!
Ezt a készüléket sok sok kontakt hibával javítottam. Töbször is szét kellet szednem,mivel a panel alulról nem hozzáférhető. Sajnos úgy jártam vele,hogy amikor már szinte teljesen tökéletesen működött és már csak az egyik oldal reléje volt egy nagyon kicsit kontaktos,még egyszer utóljára szétszedtem. Meg is találtam a forrasztási hibát,ki is javíottam,de amikor összeraktam,nagy megdöbbenésemre csak egy nagyon gyenge (teljes hangerőnél is) hang fogadott a rádiórészből. Sok méricskélés után rájöttem,hogy a bemeneti szelektor IC(TC9163) nem kapcsol át. Ha a bemenet és kimenet lábait átkötöm(pl:25-24 vagy 4-6) akkor természetesen tökéletesen szól. Amit megfigyeltem: Ha nincs átkötve,akkor teljes hangerőn hallani egy szűrődő hangot a rádiórészből. Bárhová kapcsolom a bemeneti választót(az előlapon mutatja a led hogy vált) mégis mindíg a rádió rész hangja szűrődik át.Megmérve a szelektor ic-n a tápokat rendben megvannak. Viszont amit furának találok az az,hogy az ic 15-ös lábán az órajel,egy torz háromszöghöz hasonlít ami alig 250mv. A 16-os data lábon úgy tűnik,hogy a jel megfelelő aránylag négyszög,rajta van az adat impulzus csomag és 1V kb. Arra gondoltam,hogy le kellene resetelni,hátha segítene. Viszont nem találok hozzá semilyen infót. Próbáltam már gombok sok kombinációjával bekapcsolni,hátha resetel. Sajnos nem. Ha valakinek lenne egy jó tippje
megköszönném. Persze arra is gondoltam,hogy nem e statikus elektromosságot kapott a kezemtől,mert a vezérlőprociban van C-MOS rész is (a forrasztóm antisztatikus).
üdv.
Harman Kardon mas-100 erősítő rca bemenet átalakitása/MEGOLDVA/
Sziasztok! Vásároltam a címben szereplő erősitőt. Sajnos a torony másik eleme/vezérlő/ nincs meg hozzá. Erősítő bekapcsol, mind a kettő oldal tőkéletes. Viszont a bemenete TLC081 el van megoldva Kérdésem az, hogy sima rca be menetet hogyan lehetne kialakitani? Üdv:atis76
