SIGMA 20-40 F2.8 EX DG FOR-CANON LENS PARTS
STILL CAMERA - SERVICE MANUAL
902.8 KB
STILL CAMERA
Looking for similar sigma manual?
SIGMA 20-40 F2.8 EX DG FOR-CANON LENS PARTS service manual (1st page)
Preview of SIGMA 20-40 F2.8 EX DG FOR-CANON LENS PARTS [1st page]
SIGMA 20-40 F2.8 EX DG FOR-CANON LENS PARTS service manual (2nd page)
Preview of SIGMA 20-40 F2.8 EX DG FOR-CANON LENS PARTS [2nd page]
    SIGMA DG FORCANON LENS 2040 F2.8 EX 20 40 FOR CANON 20-40 FOR-CANON
Sony kamera HDD format error E:31:00 hibaüzenet
Üdv! Mit lehet ilyenkor tenni? Mitől lehet? A menüben sem engedi formatálni... :( 100GB Toshiba HDD van benne.
DCR-HC39E Flange Back Adjustment.
Adjusting method:
Order Page Address Data Procedure
1 0 01 01
2 E FD
Set the bit value of bit4 is
“1”, and press PAUSE
button. (Note 6)
3 6 01 13 Press PAUSE button.
4 Wait for 2 seconds.
5 6 01 15 Press PAUSE button. (Note 7)
6 6 02 Check the data changes to
“01”.
7 6 0C Check the data is “00”.
8 F 57 Check the data is “00” to
“0B”.
Note 6: For the bit values, refer to “6-4. SERVICE MODE”, “4-
3. 3. Bit value discrimination”.
Note 7: The adjustment data will be automatically input to page:
F, address: 11, 48 to 58.
I've done lots of flange back adjustments on other Sony camcorder models but, on this one, when I went to instruction 2, page E, address FD, the data was 40, so I change that to 39 (giving a bit4 value of '1' ) and pressed the PAUSE button (to write to the registry), and carried on with the other instructions. As soon as I changed page E, address FD,  data to 39 the screen of the camcorder went black and stayed like that throughout the other instructions. As nothing seemed to happen, I went back to page E, address FD, and changed the data back to 40 and pressed the PAUSE button, to write to the registry. The camcorder seemed to start running through its automatic flange back adjustment, but then seemed to be bricked, with error E:60:00 displayed and the focus lens vibrating rapidly back and forth at a high frequency, giving a very blurred image. On disconnecting the adjustment commander, the camera would display no image, when turned on, just a blue screen. After 90 minutes of writing correct values to the registry, the camera went through its correct automatic flange back adjustment, and all was well.
I then tried to do the flange back adjustment on another DCR-HC39E, and just missed out instruction 2 and that worked fine and made correct adjustments. Is the service manual incorrect, or am I missing something?
Olympia C500
Sziasztok! Szeretném tudni, milyen elem való ebbe a készülékbe. Nem a 2db ceruza érdekel, hanem a taszter alatt elhelyezett beforrasztott áramforrás. 3V-os lithium, vagy 1,5V-os gombelem? A Sanyo feliratot el tudom olvasni, de ponthegesztéssel rárögzített két forrfül takarja a típusát. Kiindulás: A fényképezőgép életjelet nem ad. Az elemfészekben zöldes oxidnyomok. A burkolatot eltávolítva a csatlakozó felületeket kitakarítottam, és a bekapcsoló gomb alatti panelon a felforrasztott elem sarkain 180mV-ot mértem. Ez kevésnek tűnik. 1,5V-os góliát elem volt itthon :-) arra nem reagált. 3V-ot pedig nem mertem még adni neki. Ismeri valaki a lelkivilágát? A segítő válaszokat előre is köszönöm. Imre
JVC Kamera, GR-SX22, E03 kod / megoldva, köszönöm az ötleteket!
Tisztelt Urak! Segítséget kérnék a GR-SX22 videokamerával kapcsolatos problémát illetően. E03 hibakódot ír, a behelyezett kazettát nem ismeri fel, ( játékidő). Felvételnél kb 10 másodpercet vesz, utána a következőket írja: Unit in safe guard mode, Remove and reattach battery. Kérem szíves segítségét aki találkozott ilyesmivel. Nem szívesen dobnám ki a cuccost. A segítséget előre is köszönöm. Szép estét kívánok. Galibali
