Philips HTS513112 Soundbar -hoz értő szakit keresek!
Torz, majd elhalkul.
Ismeri valaki? Tudja javítani valaki? Anyag?
Van hozzá a Tanyán Service Manual.
Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Üdv Tisztelt mesterek!
Segítséget kérnék.
Javítok egy Rodek RI-4100 erősítőt.
Egyik csatornába dióda lett egy tranzisztor.
A tipusa C556B. Gondolom 2SC556B.
Jaeger szerint: Si-N UHF,Drv 40/20V ,0.4A 850MHz.Tok TO39.
Már ez nem stimmel , mert TO92 kis BC tokban van.
Helyettesítőnek :2N3866 -t hoz, az sem jó , mer abban tranzisztor vizsgálóval egy dióda is van.
Mi lenne ez és honnan szerezhető be?
Sajnos nincs rajzom sem hozzá.
Tisztelettel :Öreg Tom
A gép működik!
BC557B lett betéve.
Remélem hogy működni is fog.
A társ csatornát is cseréltem, hogy egyszerre nyisson a két csatorna.
Ezek lesznek a kisebb terhelésű ( szett) , és az az eredeti jó csatorna a Wooferé maradt.
Kíváncsiságból megnéztem a végfok párokat.
Hát ez bizony keményen párba van válogatva.
hFE:89/90 TIP35/36 , másik cstorna : 88/89
Köszönöm mindenki segítségét.
Tisztelettel: Öreg Tom
A képen látható sztereo equalisert kaptam egy cimborámtól. Magyar gyártmány, a nyolcvanas évekből. Mivel két oldalas, furatgalvános, ónozott nyákja van, elég valószínű, hogy nem holmi kisipari tákolásról van szó, de nem tudom, hogy pontosan minek a mije is ez?
7db TL084 van rajta, és az összes jelölés mindössze egy "PCB23" felirat.
Nagyra értékelném, ha valaki meg tudná mondani, hol keressem a kapcsirajzát, mert sajnos jópár Siemens kocka le van róla bontva, én meg, ha nem muszáj, inkább nem fejteném vissza az egészet csak azért, hogy kiszámolgathassam, hová, milyen kondi való.
