SONOFON PRESTIGE-439U 1942 SCH
Type: (PNG)
244.2 KB
Looking for similar sonofon manual?
    SONOFON 1942 PRESTIGE 439 439U
Mackie ProFX12 V2 Request for schematics and repair knowledge
Hello, I am in the process of repairing the Mackie ProFX12 V2 mixer for a client, and am running into the unavailability of schematics. Does anyone have a copy they could share? I have already reached out to Mackie directly but am still waiting for a reply.
Additionally, I am having trouble identifying the failure mode for the two channels that have failed: one produces loud static (indicating bad op-amp or feedback resistor perhaps?) and the other has the right channel producing a 60hz hum, the other is functional. (see board photos, with the two failed channels being marked with "F". The browned area is residual flux from having replaced two opamps, and having reflowed other components around them)
Any help on either of these fronts would be invaluable. I have mainly worked in laptop and computer repair, and am just getting started with my first scope and first set of board level repairs.
SA-AX710 erősítő
A fenti Technics házimozi erősítő hangfal nélkül nulla meghajtás mellett is időről időre overload hibakiírással lekapcsol. a végfokok enyhén melegszenek. Valószínűnek tartom az egyik végfok ic haldoklik beszerezhető ez egyáltalán? RSN33S5-P
ITT Nokia st 741
Egy ITT Nokia ST 741- es music centerhez keresek magnó dekket. Ha valakinek lenne ilyen kérem írjon. Előre is köszi a segítséget.
Onkyo TX7830-nel a hangerogomb forgatasara a hangszorok membranjai ki/be mozdulnak.
Sziasztok. Van ez az Onkyo Tx7830 radios erositom. Mukodik rendesen, de ha a hangerogombot (jel nelkul) gyorsan forgatom fel vagy le, a melyhangszorok membranjai kifele ill. befele mozdulnak. He elegge gyorsan forgatom, a vedelem le is tilt. Lassu forgatasnal ez a jelenseg nem jon elo. Van a Tanyan s.m. rola, nezegettem is, de nem latom a kapcsolatot a hangero novelese v. csokkentese es a membranok mozgasa kozt. A hangeropotmeter es a meghajto ic. bemenete kozott van egy muveleti erosito, es ez galvanikusan le van valasztva ugy a potmeterrol, mint a meghajto ic-rol.  Ha valakinek lenne valami konstruktiv otlete, ne tartsa magaban. Koszonom.
