SONY BVH-3000PS BVH-3100PS MAINTENANCE MANUAL VOLUME2
VIDEO-DVD - SERVICE MANUAL
2.0 MB
SONY BVH-3000PS BVH-3100PS MAINTENANCE MANUAL VOLUME2 service manual (1st page)
Preview of SONY BVH-3000PS BVH-3100PS MAINTENANCE MANUAL VOLUME2 [1st page]
SONY BVH-3000PS BVH-3100PS MAINTENANCE MANUAL VOLUME2 service manual (2nd page)
Preview of SONY BVH-3000PS BVH-3100PS MAINTENANCE MANUAL VOLUME2 [2nd page]
    SONY BVH-3000PS BVH-3100PS BVH3000PS BVH3100PS BVH 3000 PS 3100 3000PS 3100PS
Sony VO-5850 u-matic közlőkerék Megoldva
Sziasztok! Segítséget szeretnék kérni, javítok egy U.matic videót és a közlókerék gumija totál halott. Tudtok esetleg olyan helyet ahol ilyen gumikat lehet szerezni, a komplett közlőkerékről lemondok mert az már a lehetetlen kategóriája. A gumi mérete 31x24x4,5 mm. Köszi a segítségeteket.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
SONY EV-S550E Video 8 nem játsza le a kazettát ,illetve zajos a kép...
Sziasztok A címben szereplő video8 hoz keresnék rajzot de sajna itt a tanyán nincsen hozzá próbáltam keresni hozzá rajzot de nem találtam . Hibe jelenség csikozva játszik le és így is vesz fel valoszinü fejhibás de kéne hozzá egy pontos tipus hogy milyen fej való bele ezért keresek hozzá gyári rajzot hogy megtudjam nézni a fej tipusát . Ha valaki tud segitsen . Már régóta megy a topik, és nem a rajz a lényeg benne. Légy szíves igazítsd ki a címet!
Sony SLV-X9 némely kazettákat csak fekete-fehérben játszik le (megoldva)
Sziasztok. Családi VHS digitalizáláshoz többek tanácsára vettünk egy állítólag alig használt 6 fejes sony-t, aztán nincs is vele nagy baj némi fejpucolás után, egy két szalagnál ugrik néha néha a függőleges szinkron, van amit szépen lejátszik de csak fekete-fehérben, van amit meg hibátlanul lenyom. Van otthon egy szintén hat fejes samsung valami, ez meg alul csikozza a képet, mintha a szalagpálya nem volna rendben. Kínomban előszedtem a régi Fishereket, ott meg szíj és idlerproblémák vannak. Úgyhogy egyenlőre van négy videom amit nem tudok használni amire megvettem. Mindenfél tanácsot megköszönök, nekem ez a vhs technológia mindig is bonyolult volt. üdv András Update: Sajnos a videomagnó német piacra készült, így csak a PAL rendszerű felvételeket ismeri. A házi vhs kamerák szerencsére PAL-ban rögzítettek, így amire kell arra jó lesz a magnó (digitalizálni). Mindenkinek köszönöm a segítségét!
