SONY CV-2100ACE
VIDEO-DVD - SERVICE MANUAL
97.6 MB
SONY CV-2100ACE service manual (1st page)
Preview of SONY CV-2100ACE [1st page]
SONY CV-2100ACE service manual (2nd page)
Preview of SONY CV-2100ACE [2nd page]
    SONY CV-2100ACE CV2100ACE CV 2100 ACE 2100ACE
SONY SLV-SX717E (megoldva)
Kellemes Karácsonyt Mester Urak! Most egy fent nevezett Videomagnó javításához kérnék segítséget, ötletet. A szalagvezető babákat -és egyéb mechanikai részeket- mozgató műanyag alkatrész egy helyen szétrepedt, a babákat nem tartja fixen, a mechanika összekuszálódik fűzés közben. Keresem tehát a mellékelt képen lévő alkatrészt! Egyenlőre nem leltem rá sehol. (két SONY gépet is szétszedtem, mindkettő SLV-típusú hifi gép, a háromban egyetlen egymásra hasonlító alkatrész sincs) Esetleg valakinek, esetleg valami beszerzési forrás? Köszönöm, előre is! Tibor
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony SLV715 kép van hang nincsen..
Sziasztok Van egy Video magnóm a tipusa SONY SLV-715 a következő hibát produkálja a kazettát betéve elindul a lejátszás kép van hang nincsen a kijelzö nem számlál a kép kb 2mp enként elmegy majd újra van kép és a traking led villog folyamtosan ,ha valakinek lenne ötlete hogy mi lehet a baja ,fejet megtisztogattam de semmi eredmény más ötletem most nincsen táp rendben van elkók jók a feszültségek meg vannak ...
Sony SLV-736EE Tápegység hiba
Sziasztok Van egy SONY SLV-736EE Tipusu videómagnom ami egyik napról a másikra nem kapcsolt be. Megvizsgálva a tápegységet sajnos semilyen feszültséget nem ad ki kiszereltem a videóból és egy kis fémdobozba szerelve a táp külön van tipusa HS-528SF ha valakinek lenne ilyen tápja bontva vagy roszvideója amiben ilyen van és müködik érdekelne sajna rajzot nem találtam hozzá ha esetleg valaki tudna segiteni ebben illetve mit nézzek meg benne ledeket kötöttem a kimenetekre +13 voltnál a led villog a 6 voltnál semmit nem csinál és a -13 voltnál is villog a led amikor feszültség alá helyezem . Ha valaki tud segitsen előre is köszönöm..
