Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
Hello!
I'm looking for service manual for SONY PXW-Z190V / PXW-Z190T professional camcorder.
Be so kind if you have it to give me a download link for it.
Thank you in advance!
Kind regards,
Tibor Mendrei
Hi friends,
Üdv! Mit lehet ilyenkor tenni? Mitől lehet? A menüben sem engedi formatálni... :( 100GB Toshiba HDD van benne.
