Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
Hello,
With high difficulty, I've finally fixed the problems as fellows:
1- The harness's cut wire is welded with a classic tin and thin soldering iron.
2- The flex cable is also fixed after bypassing the worn out connexion and wrip others.
Thanks for you all.
