Hi everyone,
Could somebody tell me how I can get (or buy) the Sony AdjustStation with the adjustment manual for my old Sony A55V camera? Recently, the IBIS died in this camera, and after some time the shutter died too. This rendered the camera completely unusable. Since the camera is quite old, no repair shop near me was willing to fix it at a reasonable price. So I bought the shutter unit and IBIS on AliExpress and successfully swapped them. The problem now is that the shutter is clearly misaligned. The service manual says that after replacing the shutter and IBIS, they must be calibrated to work properly. According to the manual, AdjustStation software is required for that. The camera is very important to me as it holds many memories, so I’m determined to get it working again.
üdv: egyik ismerősöm panaszolja, hogy címbeli kamerája fél órai működés után meleg.
Megmértem, a bal oldala 35 C-fok körül van, az alján az állványcsavarnál 42 fokot mértem egy órai üzem után.
Kérdem, ez elfogadható, vagy hibára utal?
A kamera egyébként normálisan működik.
Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
Hi friends,
