SONY DVP-NS15 NS51P NS43P NS53P K56P
VIDEO-DVD - SERVICE MANUAL
7.2 MB
SONY DVP-NS15 NS51P NS43P NS53P K56P service manual (1st page)
Preview of SONY DVP-NS15 NS51P NS43P NS53P K56P [1st page]
SONY DVP-NS15 NS51P NS43P NS53P K56P service manual (2nd page)
Preview of SONY DVP-NS15 NS51P NS43P NS53P K56P [2nd page]
    SONY DVPNS-15 NS-43P NS-53P K-56P DVPNS15 NS51P NS43P NS53P K56P DVPNS 15 NS 51 43 53 56 DVP NS15 DVP-NS15
sony slv-615
Üdv! A készülék saját, szeretem mert igényes tipus és a régi felvételeket még mindig tökéletesen játsza le. Eddig. Most stereoban zúg a hangja, a mono filmekkel kifogástalan. A tanyán nincs róla dokument, egy SM jól jönne.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony SLV E177
Sziasztok! A fent nevezett videóval lenne gondom. Mégpedig az, hogy időszakosan nem veszi be a kazettát ill. nem is adja ki(ha véletlen bevette). A mechanika mozgató motorral sorosan van egy 33 ohm os ellenállat az tűzforró de annyira hogy körülötte már minden feketedik. A mechanikát tisztítottam, elvileg nem is szorul, viszont ha megmozdítom a motortengelyt akkor működik. Mi lehet a gondja? Segítségeteket köszönöm. Krisz
SONY SLV-SE727E - tracking hiba?
Sziasztok! A fenti videó az LP-t szépen felveszi, le is adja, de SP-ben tracking jellegű hibát produkál. Saját és más felvétellel is. Samuknál szokott ilyen lenni, amikor elmegy az opciója. Ami zavar, hogy SP-ben rossz, LP-ben nem. Használta az ügyfél rendesen. Kopott, vagy opcióhibás ez is? Ha valakinek van ötlete, kérem, ossza meg velem! Szép napot! Laci
