Hello everybody,
Second, when the connexion for standard flexible are cut it is possible to scratch the two parts and connect them with extension wire and welding, but in the case of the CONTROL KEY BLOCK's flexible which is used to connect the CONTROL KEY BLOCK to the mainboard, connexions are not made of copper! (carbon maybe, trying to polish will destroy them!), actually, they are worn out (see picture).
Because these spare parts are no longer available in my country, please I need your advice to fix harness and CONTROL KEY BLOCK's flexible.
Egy Sony DSC-W290 gépbe keresnék bontásból kijelzőt. Infók szerint a DSC-H20, DSC-W230, DSC-HX1 is ezt használja.
A száma pedig LMS300GC05 és a Samsung követte el...
Jani
Hello,
Here is video at the moment that the part can be seen: https://youtu.be/PjEBGFLjgM0?t=410 (from about 6:50 mins). At 10:44 is seen that the part is only in the bottom side of the slot; and nothing more detailed in the whole internet that I was able to check for about a hour.
There is magnetic field sensor - top left on the DSC07181 and on the next photo fitted on its place, so I think it should be some kind of tiny end position switch or don't know what;
Regards,
Milen
Hello!
I'm looking for service manual for SONY PXW-Z190V / PXW-Z190T professional camcorder.
Be so kind if you have it to give me a download link for it.
Thank you in advance!
Kind regards,
Tibor Mendrei
