SONY HBD-TZ140 VER.1.7 SM
VIDEO-DVD - SERVICE MANUAL
9.3 MB
SONY HBD-TZ140 VER.1.7 SM service manual (1st page)
Preview of SONY HBD-TZ140 VER.1.7 SM [1st page]
SONY HBD-TZ140 VER.1.7 SM service manual (2nd page)
Preview of SONY HBD-TZ140 VER.1.7 SM [2nd page]
    SONY HBDTZ-140 HBDTZ140 HBDTZ 140 HBD TZ140 HBD-TZ140
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony EV-C400e mechanika javítás (fogaskerék beszerzése)
Sziasztok! A fenti Hi8-as video mechanikája pörgetésnél zörög és meg is áll. Kiderítettem, hogy a bal csévélő orsó fogaskerék része el van repedve ezért összeakad a hajtó fogaskerékkel. Kérdésem, hogy honnan lehetne ilyet beszerezni, vagy hogyan lehetne javítani? Az a baj, hogy a műanyag kiszáradt és összezsugorodott. A belső fém rész szétfeszítette. Összehúzni nem lehet a fogakat. Üdv.
sony slv 777 vp nem érzékeli a kazettát
sziasztok! adott egy sony slv 777vp hifi stereo video hibás táppal. szétszedés után látszik hogy valaki már buherálta. hiányzik a táp ic tipusa: ma2831,és egy kondi felrobbant benne ,csicsog minden. tehát kérdésem hol és mennyiért lehet ilyen táp ic-t beszerezni? vagy esetleg komplett táp ha van valakinek akkor megvenném. üdv:atis
Sony EV-S9000 Kijelző hibás
Szerbusztok
Sony EV-S9000 Hi8 as videónak nincsen kijelzése a pulton meg néztem a kijelző meghajtó áramkörbe a kondik kifolytak és van benne egy converter trafó az is le égett ilyen trafót keresek ha esetleg tud valaki beszerzési forrást kérem szóljon hol lehetne be szerezni .
