SONY SS-CTB125 CTB126 CTB127 TSB133 TSB134 TSB135 TSB136 TSB137 TSB138 TSB139 TSB140 TSB141 TSB142 VER.1.0
145.1 KB
SONY SS-CTB125 CTB126 CTB127 TSB133 TSB134 TSB135 TSB136 TSB137 TSB138 TSB139 TSB140 TSB141 TSB142 VER.1.0 service manual (1st page)
Preview of SONY SS-CTB125 CTB126 CTB127 TSB133 TSB134 TSB135 TSB136 TSB137 TSB138 TSB139 TSB140 TSB141 TSB142 VER.1.0 [1st page]
SONY SS-CTB125 CTB126 CTB127 TSB133 TSB134 TSB135 TSB136 TSB137 TSB138 TSB139 TSB140 TSB141 TSB142 VER.1.0 service manual (2nd page)
Preview of SONY SS-CTB125 CTB126 CTB127 TSB133 TSB134 TSB135 TSB136 TSB137 TSB138 TSB139 TSB140 TSB141 TSB142 VER.1.0 [2nd page]
    SONY SSCTB-125 SSCTB125 CTB126 CTB127 TSB133 TSB134 TSB135 TSB136 TSB137 TSB138 TSB139 TSB140 TSB141 TSB142 SSCTB 125 CTB 126 127 TSB 133 134 135 136 137 138 139 140 141 142 SS CTB125 SS-CTB125
SONY CDX-M700R tuner rész!
Sziasztok! Ennek a sony-nak süket a rádió része, még sistergés sem hallható. A cd kifogástalanul működik, lejátszik mindent. Milyen feszültségeket kéne tudni mérni a tuner lábain?
Sony STR-DE 225 Receiver, sudden interruption of Audio, after switching off everything is ok again
Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue?  Thanks
Sony GDX 3900R
Helló tanyasi mesterek. Kaptam egy nevezett készüléket. Most szükségem lenne rá de nem boldogulok. Jelenség. Minden ok-nak látszik, csak nincs hang. Amit lepróbáltam. Végfok jó, nincs letíltva, bemenetről megy. Állomást keres összes kezelőszerv ok. Audió procin feszkók ok, de a tuner nem megy, bár ott is a feszkók megvannak. Cd megy, számol de nem szól.Órajelek mindenhol megvannak. Most én vagyok béna, vagy valami le van tíltva, vagy az aud. proci döglött. Nincs valakinek valami tapasztalata? Sajnálnám kidobni mert szükség volna rá. Kösz István
SONY TA-F590ES végfok átalakítása, tanácsok, ötletek.
Egy SONY TA-F590ES MOSFETES erősítőt szeretnék javítani. A Bal csatornában található végfok mostfetek mentek tönkre, illetve a körülötte lévő egyik tranzisztor is meghibásodott.. (2SC2275)
A passzív elemeket kiszedtem és mértem, nos szinte az összes biztosíték ellenállás értéken alul volt, ugyan ez a helyzet a működő "jobb" csatornában is. Ezeket pótoltam, cseréltem mindkét csatornában, valamint a 0,22R/2W párosokat,  2SC2275, 2SA985, illetve a 2SC3423 tranzisztorokat szintén, gyakorlatilag majdnem mindent. A jó csatornán beállítottam az RT301-el a -1,3V-ot, ez a fele szépen működik. A Bal csatornához sehol nem találok már EREDETI TOSHIBA MOSFETET, amit lehetne venni, arról még a kereskedő is lebeszét. HQ elektronika oldalon van egy helyettesítő típus ECW20P/N20, próbáltam, de nem vált be sajnos,  nyilván figyelve a D-S fordított lábkiosztásra.
Kérdésem, lehetne, érdemes e próbálkozni az IRFP9240/240 párossal?
Ha igen, mit szükséges átalakítani az eredeti áramökörön?
Találtam egy kapcsolást, (illetve megvásárolható kompletten is: https://www.ebay.com/itm/134499257800)  az IRFP9240/240 párossal ebben láthatók az értékek és az áramkör. Csatoltam a SONY végfok rajzát is (a teljes rajz fent van az oldalon)
A SONY tápfesz +/- 50V
Átalakítható e az eredeti áramkör némi módosítással, megfelelő alkatrész értékek módosításával, ha igen, mi maradhat, mi nem?
Szeretném megmenteni ezt az erősítőt, kb 30 éve használom.
Köszönöm, Üdv, Zoli
Kedves Fórumtagok,
Szeretnék emlékeztetni mindenkit, hogy a fórumunk célja a konstruktív és tiszteletteljes párbeszéd. Kérjük, tartózkodjatok a személyeskedéstől és az erkölcstelen beszédtől. Az ilyen hozzászólásoknak nincs helye sem ebben sem a többi topikban. Ezek a bejegyzések most törlésre kerültek. Köszönöm a megértést és az együttműködést.
Üdvözlettel, poczkodi77
