TEAC MV606 SM
VIDEO-DVD - SERVICE MANUAL
7.7 MB
Looking for similar teac manual?
TEAC MV606 SM service manual (1st page)
Preview of TEAC MV606 SM [1st page]
TEAC MV606 SM service manual (2nd page)
Preview of TEAC MV606 SM [2nd page]
    TEAC MV-606 MV606 MV 606
AEG-VCR 4500 gyerek zár torlése
Tudna valaki segíteni? AEG-VCR 4500 videomagnom bekapcsolás után a PL/gyrek zár/ ki írása után csak az EJECT gombra reagál.Nincs használati utasításom,kérem segtsen valaki.Koszonom.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Panasonic videó fej
Üdv mindenkinek! Minap hozzájutottam egy panasonic SVHS videóhoz és egy érdekes hibába botlottam. A kép zsizsikes.. Kikondiztam az ilyenkor szokásos dolgokat /hybrid, HQ pack/ de a hiba maradt. Kapott egy bontott fejdobszerelvényt, és lám, megjavult. Gondoltam, h biztos a motorvezérlő IC, vagy az ott lakó elkók száradtak ki, csere, hiba megmaradt. Cseréltem a forgótrafót is, ugyanúgy kása hegyek. Maradt a fej, még jóhogy. :D Cserélve szép kép, problem megoldva, fejdög. /Szkópom nics, ha lenne nem tartott volna eddig a felderítés./ Amire kíváncsi lennék : Gyakorlatilag egy bontatlan készülék volt, nem volt széthajtva, a dobon sem látszik kopás, fejek még nagyítóval nézve is épek. Mivel lehet így elbarmolni, ami nem hagy nyomot? Demagnetizálás megárthat ezeknek a zöld amorph fejeknek?
Samsung SV-455GX videómagnónak rossz a felvétele
Egy Samsung SV-455GX videó hibátlanul lejátszik, szkópon kifogástalan az FM jel, Azonban a felvétel zavaros, csak a háttérben látszik időnként a rossz minőségű kép. Időnként a felvétel kezdetének pillanatától fél másodpercre megjelenik a hibátlan felvétel, de el is tűnik, és marad a zavaros kép.
 Az igazsághoz tartozik, hogy az ÜF is belenyúlt, pl. eltüntette a fékszalagról a filcet, elállította a szalagvezető babákat.
Ha tudna valaki segíteni, megköszönném.
Üdvözlettel:
