Hello! This TESLA logo appears on this TV at startup, it stays on for so long after which the logo goes out and reappears and the issue is repeated. Does anyone have the appropriate usb update software (unless it is a more serious mainboard problem) or SPI dump? Thank you!
Mainboard: 5844-A7N01G-0P30
VER 00.07 2017.06.29
On a white label: SJX-QC JX11-11
On the other: 17C0005M01237
Display: SDL320HY (CD0-720) (14) REV: R1
MSDL320HYCD07201481FHA1763
Type: ST3151A05-8
CELL: TA810162BA07
The motherboard is monobloc, it also contains the source part and backlight driver. I have never seen this board or the display. Thank you
meg tudna vki mondani, hogy mi a szerviz kodja ennek a TV-nek.
es meg ez a tipus is erdekelne: ORAVA TVP - 555 A
elore is koszonom
imrok
Hello! At the start of this TV, the TESLA logo appears, it stays on for a while after which it goes out (the backlight goes on) and the logo reappears and the issue is repeated. I changed the MX25L1605 flash memory loaded with software found on a Russian forum, but nothing changed.Someone has the appropriate usb update software ?
It is equipped with : Mainboard : 5844-A7N01G-0P30 VER 00.07. On a white label: SJX-QC JX11-11
Display : SDL320HY(CD0-720)(14) REV : R1
Type : ST3151A05-8
CELL: TA810162BA07
Thanks in advance!
Adott a témában szereplő "csoda". Áram alá helyezve 1-2mp-re felvillan a standby led, majd kialszik és nem csinál semmit. Elkókat cseréltem, de semmi változás. A tápja egyébként vélhetően megy, mert több féle feszültséget is tudok mérni a szekunder részén. Led háttér is jó, teszteltem. Mi lehet a gond, illetve van-e értelme tovább foglalkozni vele? Szoftver hibára gyanakszom.
