Ez a autórádió nem fog FM-ben semmilyen adót, de AM-ben tökéletesen működik. A készülékben lévő tuner HK-201V, milyen feszkóknak kellene lenni a lábain, eddig van 5V és 8V semmi hangoló feszt nem mértem.
a fent említett tipusú számomra ismeretlen márkájú autósrádió bekötésében szeretném kérni a segítségeteket.Kicsit viseltes és "belepiszkált" kis szerkezet ami szerinttem kicsit még okoz fejtörést nekem ... csak ezen legyek túl első körben - a helyes bekötésen.
Köszönöm előre is segítségeteket. (csatolttam a képeket a beazonosításhoz.)
Misi
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Szeretnék készíteni egy 3 csatornás sztereo hangkeverőt. 2 aux és egy mikrofon bemenet kellene, ami nem lenne rossz ha lenne benne előerősítő is.
Ehhez kérnék segítséget, hátha már csinált ilyet valaki, vagy van valami jó kapcsolása.
U.i: Kellemes ünnepeket mindenkinek!
