TRANSFORMER CORP. OF AMERICA TC37LW SCH
40.7 KB
Looking for similar transformer manual?
TRANSFORMER CORP. OF AMERICA TC37LW SCH service manual (1st page)
Preview of TRANSFORMER CORP. OF AMERICA TC37LW SCH [1st page]
TRANSFORMER CORP. OF AMERICA TC37LW SCH service manual (2nd page)
Preview of TRANSFORMER CORP. OF AMERICA TC37LW SCH [2nd page]
    CORP. OF AMERICA TC-37LW TC37LW TC 37 LW
Thomson DPL 570HT egy csatornája zárlatos.
Üdvözletem Mesterek !
Javítanék egy Thomson DPL570 gépet
Egy csatorna zárlatos.
2SD2559 nem találtam sehol.
2SB1659 van a HQ-nál
 2SC4137 van a HQ - nál
Biztos javítottak már sokan  hasonlót.
Lehet ezt pótolni valamivel?
Vagy valakinek van elfekvő , esetleg tudnak beszerzési forrást?
Segítséget előre köszönve: Öreg T.
Kenwood KA-3500 Integrated Amp BIAS Adjust
Hello, Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape. Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors? -- On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me. -- I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were? -- The service manual is on site here. Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read. I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty. -- Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2: Bellarmine
DENON UPA-500 rádió hangolási hiba (megoldva)
Üdvözletem a Tanyásoknak.! Kaptam egy Denon UPA-500 rádiót.Tápegység javítása után és a kijelző világításának izzósról LED-esre történő átalakítása után a következő a jelenség. Az állomás keresés elindul de nem áll le mert nem talál állomást. Az Lm 7000 PLL IC 1 és 20 láb között lévő 7,2 MHz-es kvarc kimenetén szkóppal vizsgálva nem látok jelet.Szerintetek a kvarc a rossz vagy az IC? Milyen tapasztalatok van ehhez hasonló hibák esetén? A mikrokontroller felől jönnek az impulzusok. A PLL IC -nél a tápok rendben vannak.Csere esetén hol lehet venni LM 7000 IC-t? Ebben a témában kérném a segítségeteket. Pistili
Genius SW-HF5.1 5005 aktív hangfal bemeneti ic hibás
A fenti dolbis cucc került hozzám, hogy nem szól. Persze már szétmatatták. Van benne egy BT2328 20 lábú csoda amit helyettesítettek PT2258-al. Sajnos nem megy át rajta a hang. Cse fórumon olvastam, hogy más is belefutott ebbe a hibába és neki se javult meg ezzel a pótlással. De megoldás ott sem született. Tudtok tanácsot adni illetve beszerezhetőséget eredeti ic-re?
Na igen megnéztem nem a némítás a probléma mert az ic kimenetéről már műkszik a rendszer és a némítás is működik utána. Rajz itt a tanyán fent van.
Köszönettel laci
A hibás cím utólagos javítása (48 órán belül) a "Szerkesztés" fülre kattintva végezhető el
