TTI-TEC TX-3030
OTHER - SERVICE MANUAL
6.4 MB
Looking for similar tti manual?
TTI-TEC TX-3030 service manual (1st page)
Preview of TTI-TEC TX-3030 [1st page]
TTI-TEC TX-3030 service manual (2nd page)
Preview of TTI-TEC TX-3030 [2nd page]
    TTITEC TX-3030 TX3030 TX 3030 TTI TEC TTI-TEC
PR-001 PR-002 Small Door Lock Switch közötti különbség [Megoldva]
Hellótok!
A TV-k, Videó-k, számítógépek, klímák kisebb ajtajaiknak a záródását gyakran oldják meg ezekkel a kis önzáródó/-nyitódó betéttel.
Nézem a különbséget a PR-001 és a PR-002 között, de nem tudok különbséget felfedezni.
Tudnátok segíteni?!
https://www.ebay.com/itm/165759368475?hash=item2698073d1b:g:msMAAOSw8klhnepW&amdata=enc%3AAQAHAAAA8B1e6tP9Qwt0uxog18tPL%2BVAvCIejEBkR7oEKAE8DAh%2BQzshc2iLtuaL4XR7iNoFU0KYOV8G30CjvuYc6dG7snO%2BfPVMTAZlIVceQRiQECSmTI1QpUWm%2F%2BFqBDOwjKT%2FRti%2FPMkGmTQvgI9GH0gsU63pWBo1UAFETC%2Brtff1HPp19JkvOHq1hI3iLTfBCLMD7qPWlNPyL2Ms7OQNoDDMOOpLMihnQCiygMPOyqVnAFelHDnELRj%2BoUMFnyLGvjEcMi0Vk3%2BOguIf5zUpu8Jj1zTu9PFAuqZTOe7wrux1fklnh6rcPHtMR94GKph1jk4tcA%3D%3D%7Ctkp%3ABFBM5OP108hh
https://www.aliexpress.com/item/1005004148159756.html?spm=a2g0o.productlist.main.7.298439efEt0qkp&algo_pvid=8f1f9120-7745-4deb-b23c-13bc2473eb75&algo_exp_id=8f1f9120-7745-4deb-b23c-13bc2473eb75-3&pdp_ext_f=%7B%22sku_id%22%3A%2212000028194624561%22%7D&pdp_npi=3%40dis%21HUF%21371.52%21334.37%21%21%21%21%21%40211bf3f816762034400023309d06e7%2112000028194624561%21sea%21HU%213437131897&curPageLogUid=FvEEFjAHDAm0
Köszönöm előre is:szuts
Removal of potting compound
Has anyone ever had success removing the hard glossy type of compound used to seal
various kinds of electronics ou there in the trade?
I am trying to get at the bobbin and diodes inside a small HV (FBT) transformer
to study the material used in construction.
I have heard there is a solution it can be soaked in that dissolves only the potting, and
leaves other material undamaged, but I dont know if its merely acetone or something else.
I tried baking in the oven a while, and it didnt seem to make the epoxied area weaker and when I tried pulling
on the pins, the pins came out.
Kínai LED-es zseblámpában a LED negatív lába előtti MOSFET meghalt.Cserélni szeretném.Nem volt rajta jelölés. (Megoldva!)
Cserélni szeretnék egy kínai LED-es zseblámpában a LED negatív lába előtti felületszerelt tranzisztort, ami tönkrement.  Sajnos nem volt rajta jelölés. Egy másik hasonló , de régebbi ilyen zseblámpából kiforrasztottam a LED negatív lába előtt lévő hasonló alkatrészt, és azt tettem bele a javítandó lámpába.  Működni működött ezután, de csak fele annyi fényerővel világított utána mint az eredeti alkatrésszel. Nem tudom milyen típust lehetne ide betenni, hogy megfelelő fényerővel világítson. Mit javasolnátok ide? Előre is köszönöm a segítséget és javaslatokat. Fotókat csatolok a lámpa belsejéről, ahol a fekete nyíl mutatja az alkatrész helyét.
