For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
üdv: itt néhány rajz elérhető,
http://oldradio.tesla.hu/rajzok/erosito/erositok.html
Csereérett lett a lemezjátszómban a tű, szerintetek mi a különbség ezek közt?
http://www.ebay.com/itm/Needle-Turntable-Kenwood-N-67-N67-Sansui-SN-P212-/261045663066
és
http://www.ebay.com/itm/KENWOOD-SANYO-MARANTZ-SANSUI-TURNTABLE-NEEDLE-STYLUS-819-D7-/270408521961
Hozzám került javításra egy Pioneer SA-708 hangerősítő. Egyenfesz a kimeneten, védelem bekapcsolva. Az első mérések után egyértelművé vált hogy az egyik csatorna végfok tranzisztorjai zárlatosak.
(2SA1075/2SC2525). Ezeket a tranzisztorokat nem találtam, 2SA1215/2SC2921 tranzisztorokat ajánlották helyette. Ezen kívűl el volt égve az R437 330ohm ellenállás, a D407 dioda és a Q411 2SA968 tranzisztor. Ezeket mind kicseréltem. Az első bekapcsolás után azonnal kiégett a biztosíték, a két végfok tranzisztor és a Q411 tranzisztor. Szerintetek hol keressem a hibát?
A Készülék kapcsolási rajza megtalálható az Elektrotanyán. Az említett részt kivágtam és csatoltam ide.
Update:
Miután újra kiforrasztottam a végfok tranyókat, bekapcsolva az R437 megint füstölni kezdett. 96 voltot mértem rajta. A Q411 és Q413 mérve jók.
Minden segítséget köszönök.
Endre
