VIVITAR SERIES-1LENS 70-20MM F-3.5 1-4X-ZOOM PARTS-LIST
STILL CAMERA - SERVICE MANUAL
22.5 MB
STILL CAMERA
Looking for similar vivitar manual?
VIVITAR SERIES-1LENS 70-20MM F-3.5 1-4X-ZOOM PARTS-LIST service manual (1st page)
Preview of VIVITAR SERIES-1LENS 70-20MM F-3.5 1-4X-ZOOM PARTS-LIST [1st page]
VIVITAR SERIES-1LENS 70-20MM F-3.5 1-4X-ZOOM PARTS-LIST service manual (2nd page)
Preview of VIVITAR SERIES-1LENS 70-20MM F-3.5 1-4X-ZOOM PARTS-LIST [2nd page]
    VIVITAR F-3.-5 7020MM F3.5 14XZOOM SERIES LENS 7020 MM 14 XZOOM 1LENS 70 20MM 3.5 4X ZOOM LIST 70-20MM F-3.5 1-4X-ZOOM
DCR-HC39E Flange Back Adjustment.
Adjusting method:
Order Page Address Data Procedure
1 0 01 01
2 E FD
Set the bit value of bit4 is
“1”, and press PAUSE
button. (Note 6)
3 6 01 13 Press PAUSE button.
4 Wait for 2 seconds.
5 6 01 15 Press PAUSE button. (Note 7)
6 6 02 Check the data changes to
“01”.
7 6 0C Check the data is “00”.
8 F 57 Check the data is “00” to
“0B”.
Note 6: For the bit values, refer to “6-4. SERVICE MODE”, “4-
3. 3. Bit value discrimination”.
Note 7: The adjustment data will be automatically input to page:
F, address: 11, 48 to 58.
I've done lots of flange back adjustments on other Sony camcorder models but, on this one, when I went to instruction 2, page E, address FD, the data was 40, so I change that to 39 (giving a bit4 value of '1' ) and pressed the PAUSE button (to write to the registry), and carried on with the other instructions. As soon as I changed page E, address FD,  data to 39 the screen of the camcorder went black and stayed like that throughout the other instructions. As nothing seemed to happen, I went back to page E, address FD, and changed the data back to 40 and pressed the PAUSE button, to write to the registry. The camcorder seemed to start running through its automatic flange back adjustment, but then seemed to be bricked, with error E:60:00 displayed and the focus lens vibrating rapidly back and forth at a high frequency, giving a very blurred image. On disconnecting the adjustment commander, the camera would display no image, when turned on, just a blue screen. After 90 minutes of writing correct values to the registry, the camera went through its correct automatic flange back adjustment, and all was well.
I then tried to do the flange back adjustment on another DCR-HC39E, and just missed out instruction 2 and that worked fine and made correct adjustments. Is the service manual incorrect, or am I missing something?
SAMSUNG S85 DIGI Fényképező
üdv.mindenkinek SAMSUNG S85 ös fényképező vakuáramköri rajzát vagy az egész gépét keresem.
Fuji Finepix S602z objektív mechanika sérült
Üdv mindenkinek! Saját fényképezőgépről van szó, vélhetően elejtették (de a családban mindenki tagad). Az objektív mechanikában 3 kis apró görgő mozog az objektív palástban levő járatban (ahogy az már lenni szokott). A görgőket 1-1 kis csap tartotta, míg le nem törött kettő is. Az elektronika vélhetően tökéletes, de mivel az objektív működésképtelen, hibával megáll a gép. Ha valakinek volna döglött elektronikájú, ép mechanikájú gépe, szívesen eldiskurálnék arról, hogy neki legyen jó elektronikája, vagy nekem legyen jó mechanikám...
Canon PowerShot SX10 IS kikapcsolás után "elfelejti" a dátumot
Canon PowerShot SX10 IS típusú fényképezőgépem kikapcsolás után folyton "elfelejtette" a dátumot. Csak azért írom meg, hátha valaki nem ismeri az okát. Ez a jelenség akkor jön elő, mikor a benne lévő CR1220 típusú gombelem lemerül. Ugyanis ez tárolja a dátumot és az időt. Csere után ismét tökéletesen működik a fényképezőgépem.
