A címben említett készülék bekapcsolás után 1-2 mp. kikapcsol. Ezalatt a rövid idő alatt a funkciók működnek(hangerő, bemeneti választó stb.)
Amennyire tudtam átmértem,végfokozatt,táp jónak tűnik.
Nem igazán tudom merre kellene tovább keresgélni.
Ha van valakinek tapasztalata, ötlete kérem ossza meg
köszönöm.
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Kaptam egy gányolt erőlködőt,először beakartam dobni a többi lom közé...de miután kicsit megvizsgáltam és kiderült a panelja sértetlen,végfokok eredetiek és hibátlanok úgy döntöttem helyre pofozom.Hangerő gombja hiányzik de van esztergám, meg képem az eredetiről ez nem probléma,még a venti lyukat kell szépen eltüntetni a hátuljáról.Lesz vele pár óra munka de imkább mint hogy hulladékként végezze.
A legnagyobb gond hogy valami "mester" belefabrikált 2 db kisebb toroid trafót(OLP 3D817)+ventillátort mellé(gondolta a kis trafók majd bírják árammal ezt az erősítőt ha hűti őket)amik szépen primer zárlatosak is lettek.Kerestem neten de sehol nem találok róla rajzot(tanyán sem) hogy milyen feszültségeket szolgáltathatott eredetileg.Ránézésre 2 szimmetrikus tápfeszültségről üzemel.2db 3300Mf 25V és 2db 8200Mf 63V pufferrel.Gondoltam megkínálom +-15V és +-42v-al,de ha esetleg valaki ismeri a gyárit maradnék az eredeti értékeknél.
Hátha valaki tudna segíteni.Köszönöm.
Nevezett erősítő került hozzám, tápegység hibával. Nemrég járt szervizben, de pár hét után ismét megadta magát. Láthatólag két alkatrészt cseréltek benne: R419/D405
Most ugyanez az ellenállás égett szét. A zener jó, viszont nem tudom az eredeti jelölése mit takarhat. Helyette Z10M lett berakva (ez sem sokat mond)
Jó lenne konkrétan tudni, mik lehettek, mert addig nem látom értelmét továbblépni és a tönkremenetel okát keresni.
Üdv,Z.
