I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Sziasztok. Elozmenyek: az amplituner hibasan kerult hozzam, nem adott semmi eletjelt. A vegerosito egyik csatornajanak vegtranzisztorai voltak zarlatosak, az egyik meghajto ossze-vissza vezetett, es az egyik vegtranzisztor emiter ellenallasa volt megszakadva. Sajnos az eredeti tranzisztorokat csak eleg borsos aron lehet beszerezni, igy a hibas vegtranzisztorok helyebe BD249c/250c paros kerult, meghajtoknak pedig a 2SA1013/2SC2383 paros. Ezek utan a javitott csatornan mert feszltsegek nem igazan egyeznek a szervizkonyben szereplokkel. A mert feszultsegeket rairtam a beszkennelt rajzra. VR102 - bol beallitottam TR122 bazisan a -0.5v-ot, de a vegtranzisztorok bazisan csak +-0.44v van, az emiterellenallason nem merheto feszultsegeses. Ennek ellenere a csatorna mukodik/szol egy nelkulozheto probahangszorot rakotve. Sajnos szkopom nincs, igy nem tudom megvizsgalni a jelatvitelt. Kerlek adjatok valami tanacsot hol lehet a gubanc?
Sziasztok, segítséget szeretnék kérni. Adott egy Yamaha rxv559, ami nem kapcsol be.Fő relé nem indul el .Amit meg tudttam nézni,illetve kimérni:
-a 10v a kicsi trafó után meg van
-az ominózus kondi cserélve ami a tápot választja le a tc ic nek
-5v (+5m) , 10v (s10) felmegy a dsp panelre, ott ami van 10/5v os stab kocka az jó
ami hiányzik az a : pdet, res ,5v - ok
A proci megkapja az 5v -kat.
Azt kérdezném hogy ez a kettő hiányzó táp az a dsp panelről jönne vissza, vagy a táp panelről menne fel a dsp panelra.
Esetlegesen van ötlet mit tudok még meg nézni?
válaszotokat előre is köszönöm Tams
Yamaha psr-s500-as szinti kijelzőjének egyik fele ne működik. Minden egyéb működik rajta, kontrasztot tudom állítani viszont a jobb oldala a kijelzőnek ha feltekerem a kontrasztot teljesen elsötétül ha leveszem a kontrasztot teljesen világos. Segítségeteket kérném, hogy hogyan tudnám megállapítani hogy a kijelzővel vagy a vezérléssel van a gond?
Üdv.: Norbi
