I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Looking for the schematics for a Yamaha MCR 640=CD 640
Not the schematics for the YAMAHA NS-BP300 R-840 MCR-640 MCR-840 MCR-940.
This service manual is for the R-840/NS-BP300. For the service manual of the BD-940/DVD-840/CD-640, see to the following publication numbers:
BD-940: 101154 / DVD-840: 101155 / CD-640: 101156
THANKS
ellemann
Adva van a megnyitóban említett erősítő, amelyet nem lehet bekapcsolni. A táp megoldását nem ismerem. Ha valamelyikőtöknek volt már ilyen problémája szívesen venném a segítségét.
Üdv.Ckó
Segítséget szeretnék kérni egy Yamaha HTR-4071 feltámasztásához.
Az erősítő nem indul. Self-diag módban el tudom indítani, a PS1 körön van valami gond.
Ebbe a körbe tartozik: AC_BL, AC_12, +/-7A, +3.3S feszültségek.
A +/-7V, a +3.3V és AC12V méréseim alapján rendben vannak.
PS1_PRT értékének a kijelzőn 29-118 sávban kellene lennie, nálam 178-183 között mozog.
AC_BL lehúzott csatlakozónál "E" ponthoz képest egyik fele 10.6V, másik 20.3V, ha a csatlakozó a helyén van akkor 13.6V és 20.3V.
Két AC_BL között 10.5V.
Ezek egyből a trafóról jönnek. Szerviz doksi 98. oldal (nyák) illetve 112. oldal (kapcs.rajz).
Trafó száma: YJ279A0 (SM 8126 SET)
Szerviz doksit feltöltöttem ide: https://elektrotanya.com/yamaha_rx-v483_htr-4071.pdf/download.html
Mit kellene megnézzek?
Jó lenne behatárolni melyik ágon van a hiba anélkül, hogy további kárt tennék benne.
Szét tudom valahogy választani az ágakat? Sajnos nem látom át, hogy végül hogy áll össze a proci lábán a PS1_PRT jel. :-(
Az erősítőt hibásan vettem, saját részre szeretném feltámasztani.
Üdvözlettel:
Gábor
