I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Került hozzám ez készülék a fent jelzett hibával, az egyik kimeneten (L) jó 50%-kal gyengébb jelszíntett mérek, szkóppal nézve is jól látható a különbség, zavar vagy gerjedést nem látok a jeleken se a jó csatornán se a rosszabbikon,
De jelszintek iszonyatosan eltérnek, ha teljesen feltekerem a hangerőt akkor is kb 15-20Vpp mérek a szkópon, a másik csatornán nagyság rendel többet, még közép állásban is.
Feszültségeket mérve mindent jó értékek közelében mértem.
Sajnos nem tudom hogy mi okozza ezt a hibát.
Ha valaki találkozott ilyen hibával kérem adjon nekem valami ötletet, hogy merre érdemes kutakodni.
Ezt a rádió funkciónál tapasztalom, jelet még nem adtam rá a bemenetre, sajnos nem tudom hogy ez a hiba ott is fenn áll e, erre már nem maradt időm.
Köszönettel: Istva78
Üdv Istvan78
Ez a receiver egy kissé megfogott.A végfok Ic (STK 2030) cseréje után is a teljes tápfesz. a hangszórókimeneteken.Kettő ellenállás elégve, ezeket természetesen cseréltem.Esetleg a új SINI-től vásárolt végfok IC rossz?A hozzászólásokat köszönettel veszem.Rajzom nincs hozzá, ez is bonyolítja a helyzetet.
Tónió
Üdv Mindenki!
A fenti készülék távirányítója hol megy, hol nem.
A távadó IC típusa JT-7062-2. Az IC körül minden alkatrész átnézve, Infra LED ellenőrizve, a tápot az IC megkapja. A panel erős nagyítás alatt is és a szakadásvizsgálóval is mérve hibátlannak tűnik.
Van rajta egy 3,64MHz-es 3 lábú rezonátor, aminek működését oszcilloszkóp hiányában sajnos nem tudom ellenőrizni, pedig én arra nyanakszom, mert gyakran koppant a padlón.
Szerintetek mi más lehet még?
Az alábbi távok jók elvileg hozzá:
- RAV14 V694130
- RAV205 V4732200
- RAV206 V6940901 és V6940900
Köszi
