YAMAHA TX-350 TX-350L AM-FM TUNER
2.2 MB
Looking for similar yamaha manual?
YAMAHA TX-350 TX-350L AM-FM TUNER service manual (1st page)
Preview of YAMAHA TX-350 TX-350L AM-FM TUNER [1st page]
YAMAHA TX-350 TX-350L AM-FM TUNER service manual (2nd page)
Preview of YAMAHA TX-350 TX-350L AM-FM TUNER [2nd page]
    YAMAHA TX-350 AMFM TUNER TX350 TX350L TX 350 350L AM FM TX-350L AM-FM
Yamaha CDX-590 laser adjustments?
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players. I have changed the laser unit (KSS-210A) but this didn't solve the problem. When I turn the player upside down, it plays the problematic CDs without a problem. That's why I think the laser needs adjustment. I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590. It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual. Here is a picture of the PCB. http://www.volny.cz/hwtest/PCB.JPG Here are the "test mode" sections of the service manual. http://www.volny.cz/hwtest/TM1.GIF http://www.volny.cz/hwtest/TM2.GIF In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one. So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode. It didn't help. Mode 1 - only a short blink of two horizontal dashes on the display and thats it Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on Mode 3 - seems to be very short as mode 1 I think I'm missing something ... Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser? Or maybe the problem is not the laser?
Yamaha K-M77 furcsa hiba
Van egy Yamaha K-M77 deckem, ami magától "újraindul".
Ezalatt azt értem, hogy olyan mintha lejátszás közben ki-be kapcsoltam volna, csak ezt magától csinálja.
Van olyan hogy egy ilyen után nem reagál semmire, csak a lejátszás irányát mutató ledek világítanak.
De ha kikapcsolom, és utána be, akkor rendesen működik tovább.
Én egy valamire tudok gondolni ami ezt okozhatja, van benne egy szép nagy IC, ami gondolom vezérli az egészet, én ennek a hibájára tudok gondolni.
Yamaha rx-v450 random újraindulás
Van egy yamaha rx-v450-es erősítőm amit elég rég nem használtam.
Most próbáltam ismét használatba venni, de sajnos lett vele valami.
Egy kis használat után random újraindulgat.
Valamikor el sem tud indulni.
Indulásnál behúz benne egy relé majd ki is kapcsol, ismét behúz majd ismét elejt.
Áramtalanítom várok egy picit akkor elindul, de kis idő után ismét kezd újraindulni.
Valamikor 10 percig megy, de valamikor csak 1 percig.
Van valakinek esetleg ötlete, hogy mi fáradhatott el benne?
Velemenyek a Yamaha P2040 erositorol
Sziasztok. Adott a cimbeli erosito (vagy inkabb csak erolkodo). Ugy nez ki, mintha egy profi, 4 csatornas, hidalhato erosito lenne. Nagy csalodas volt, amikor beleneztem a szervizkonyvbe. 2 drb sztereo STK van benne, 2x35w talan fejenkent. Itt kezdett erdekelni a dolog, kivancsi voltam hogyan oldja meg egy STK 2 csatornajanak a hidalasat......  Hat, sehogy. Barhogy is neztem, a 2ch/4ch kapcsolo a hatlapon csak annyit csinal, hogy megnoveli a tapfeszt. De hogy a kapcsolo 2ch pozitiojaban miert ne lehetne mind a 4 csatornat hasznalni, nem ertem. Hisz a koppanasgatlo relek is egyszerre huznak meg, a bemenetek is aktivak maradnak...
Na mindegy, csalodas ez az erolkodo. Olyan, mintha ugyanabban a csonakban evezne a Bluetech-el es tarsaival, amiket megspekeltek egy blustucc-al, memoriakartya olvasoval, esetleg fm radioval. Csak hat a nev, na....
Mindezt azert kerdem, mert talaltam egy ilyen elado erolkodot, es meglodult a fantaziam, hogy mi mindent tudnek kezdeni a dobozaval....
