Sziasztok ! A fenti készüléket szeretném átalakítani sajnos korán vált sztereóra automatikusan és még jelentős zajjal ! A manuálban nem találtam ere semmi utalást ki vagy bekapcsolásra. Jól jönne szervizdoksi , a TUNER -ic nem tudom beazonosítani ! Mellékelek róla képet talán tud valaki segíteni. 4704D60GU felső sor 1309DCFOUA alsó sor ! Üdv!
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Kedves lakók! Került egy ilyen típusú hangfal hozzám, a pár méllyet már ujra peremeztem, de a magassugárzók néma leventék HG2.5/1638 típus száma. Egy pár pillére lenne szükségem,csak eredeti érdekelne és az egyik közép sugárzó már hiányzott belőle,HB 10/1018 a másikat is újra peremeztem.Ha lenne valakinek, bontott akár perem hibás eredeti 1DB közép és egy pár pille megvásárolnám.Tudom hogy a H2000 még gyártja ezeket a hangszórókat,de a kora végett inkább eredeti érdekelne! T:Zsolt
A fenti IC-t keresem bontottat, ha lenne elfekvőben.
Köszönöm
