Jo napot mindenkinek!! Hoztak hozzám javításra egy Videoton RA-4312 SG-s lemezjátszos rádiot. azzal hibával hogy a lemez lejátszásakor csak az egyik hangszoro szol és a rádio néha szol,néha nem. A lemezjátszoban sajnos a fej a hibás-VK4203. Esetleg hol lehetne ilyet beszerezni??? A rádio részben pedig a hangolo kondenzátor a rossz-ha kicsit megütöm müködik. Lehet ezt javítani,esetleg valakinek lenne otthon elfekvö készletben?? Ja,s találtam még a rádiobak kiesve ezt a tü szerü dolgot,ennek vajon hol lehet a helye??? A válaszokat elöre is öszönöm-Stanley
Dear Friends,
I am having a problem with the above mentioned amp. When I increase the volume from 0 to a quarter level the sound is OK. If I increase the level above quarter onwards , the sound becomes fuzzy and distorted. I have tried replacing the 2 filter capacitors(8200uf 50v) with 2 (15000uf 50v) caps but it is the same. Can someone give me a clue what can be causing this problem.
Thanks
Carlos Rajoo
Üdv mindenkinek.
A fenti mini HiFi rajzára lenne szükségem. Ha valakinek megvan, megköszönném.
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
