Hi,
I'm sorry for writing in English, but I don't understand any single word in Hungarian and I couldn't find an English subforum there.
I have changed the LVDS controller and now it's working perfectly, but I need help with the backlight. The CCFL lamps in the screen are OK. I connected the screen to another inverter (from BenQ T705, made on TL1451 which also has "protect" function) and the backlight worked perfectly. Again, I connected other screen to the malfunctioning ILPI-075 inverter and the screen also goes blank.
I changed all THT electrolytic capacitors on the board, but not much has changed. Before, the backlight was turning off almost immediately, now it glows for 1-2 seconds and then turns off.
The HV side of inverter transformers is about 470 ohm, they look OK.
I measured random capacitor in the +16V line, which is supplying the high voltage inverters.
We can see how the voltage went down while the backlight was powered on.
Also, the ON/OFF signal on ICL837's pin 8 is always present after powering up the power supply, even after the backlight turns off.
I don't have any idea what to check now..
Kedves elektro tanyázók az adott hangpanel beépítve van a monitorban , az alapvető nagy kérdés az lenne milyen háromlábú állat lenne a panelt meghajtó kapcsoló üzemú táp IC Mivel szublimálódot a fenn nevezett háromlábú állat tokozásának írott fele ezért nem tudom a típusszámát , ha valaki javított ilyet és emlékszik a táp iC típusára megköszönném a megosztását a tudásának.
Üdv: teodor.
A mult heten kicsereltem par elkot ebben a monitorban,nem mukodott,a led se gyult ki,ket napig hasznaltam az en sz gepemel.Ma elvitte a kolegam ,Felhivott telefonon hogy ez jelenik meg a kijelzon: Auto config,Please Wait.Azt monja mielott lealt teljesen akkor is ezt irta ki.Mit jelent ez miert irja ki?Holnap hozzak vissza.
Kérdezném,hogy van-e valakinek Acer al1715sm lcd monitorhoz vezérlőpanelje?
