i have a very nice vintage DBX BX3 amp on which at least one channel fused.
power transistors literally burned down.
it is a very nice piece of hardware (4 channels with BTL capability 4x125W or 2x300W)
I would like to fix it myself. Having an electronic engineering degree, i think I should be able to undertake that venture but I never practiced (i've been in software for the last 40 years...)
So I need some guidance on the methodology to diagnose and track what went wrong.
I do have a scope, signal generator and I guess all required tools, as well as the schematics of the amp.
what I need is some help on locating the key parameters to measure and how to incrementally explore the different stages of the amp to find the faulty sections.
I guess I need to isolate the different sections of the amp but then, what ?
any help and advice will be highly appretiated.
Want to share:
Have downloaded the schematics from this forum to help repair the amplifier of a friend.
Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies.
When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps.
Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another.
What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore.
Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
Hi all,
I need a little help to repair my Akai PM-750 amplifier (part of system mx-750).
The voltage selector has broken and I don't know wich wires shoud I put together to get it work under 240V.
Service manual is no help, they just give spares parts...
Huge thanks to who could help me :-)
Pár hónapja hozzám került egy Music Air MHD-2400 típusú régi kazettás deck, megkímélt szép állapotban. Beindítható, nagyrészt működik is (igaz, jó nagy nyávogással indul, de azt majd a szíj cseréje megoldja..), leszámítva, hogy az előmágnesező részbe, ill. az azt tápláló oszcillátorba korábban belekontárkodtak, aminek eredményeképp felvételkor tökéletesen töröl, de csak recsegő, beütésszerű hangokat rögzít.
Próbáltam több helyen is kapcsolási rajzot keresni hozzá, de annyira ritka típus, hogy sehol nincs hozzá a neten, még fizetősen sem.. Szóval végül nekiálltam visszarajzolni a látottak alapján az oszcillátorblokkot.
Az eredményt csatolom, remélem nem nagyon hülyeség, mert ehhez nem nagyon értek amúgy, inkább a hangfrekis erősítőkben vagyok otthon.. A 'kis X-ek a két körrel' azt jelzik, hogy ott a panelen van furat, de nincs beforrasztva semmilyen alkatrész, ott valószínűleg hiányzik valami a gépből.
A 'dobozka a kérdőjellel' pedig a második képen a bekeretezett rész, ugyanis ott rájöttem, hogy onnan sehova nem megy tovább a jel, így nyilván nincs előmágnesezés. Az alsó egybefüggő fóliasávból megy egy átkötés a két előmágnesezést szabályzó potméterhez, ill. az előttük levő kondihoz. Fölül meg a trafó megcsapolásai vannak odavezetve. (Hogy a fóliát ne sértsem fel még több helyen, nem ott kötöttem össze a két sávot, hanem a képen is látható szürke vezetékkel.)
Nos, ezekből mind a 3-at külön kipróbáltam összekötni az előmágnesező résszel, aminek eredményeképp már rögzít a készülék, de továbbra is besúg, torzít a magasabb hangokon (kb. mindhárom kivezetéssel ugyanúgy). És közben ezzel együtt megjelent még egy hibajelenség, mégpedig hogy az oszcillátor megindulásával egy magas, fütyülő-sípoló hang jelenik meg a kimeneten, ami a szalagra is rákerül. A gerjedés szintje és frekvenciája változik, ha a szalagtípus kapcsolót más állásba hozom, de akkor még látványosabban, amikor a főpanelen az előmágnesezés szabályzó potmétereket tekerem.
Szóval egyelőre itt tartok, és meg is akadtam kissé. Most ez a gerjedés hiányzó alkatrész miatt lehet, valamelyik elem meghibásodott; netán a kapcsolás sem lehet eredeti, mert elvi hibás? Illetve, sajnos se analóg - kHz-es tartományban is jól mérő - multim, sem pedig szkópom nincsen - ezek nélkül lehet egyáltalán tovább haladni?
http://kepfeltoltes.hu/150823/musicair_001_www.kepfeltoltes.hu_.jpg
http://kepfeltoltes.hu/150823/1171883847musicair_002_www.kepfeltoltes.hu_.jpg
