AM-301 1974 SCH RUS.
562.0 KB
Looking for similar am manual?
    AM-301 RUS. AM301 1974 AM 301
Samsung max wb 630 HiFi
Sziasztok! Evvel a toronnyal az a baj, hogy az előlapi gombokra nem reagál, mit ha valami gyerekzárban lenne.Nen találtam semmit a kezelésiben és adoksik között sem.Távról működik. A segítségeteket kérném a megoldáshoz. Köszönöm : Laci
Klipsch ProMedia 2.1 Amplified speakers
Original problem is no sub woofer output. Been through this one and recapped it and the common 2 burned 1K (R16/17)
resistors are replaced but the sub is still not responding. Volume control potentiometer is a common issue on these but
the L-R spkrs sound good.
Went by this webpage on the repair:
https://christopherbradshaw.net/The_Project_Bin/klipsch%20promedia%20subwoofer%20repair%20-%20page%201.html
On the schematic there is a sub-relay (sw101) powered by +V_HF line it
maybe is suppose to be +V_LF ? Without the relay coming on looks like the sub is disconnected.
The zeners (D03/04) that give +/- Vcc to the op amps seemed way off so I replaced them and the voltages seem much closer.
Theres also a sub-mute line on p104 to p101. Power supply shows the LF mute relay and interconnect diagram says it
gets fed from the LF amp. What is triggering the mute? I dont see a mute button anyplace.
Camco vortex 6 full schematic or service manual please
Hello I’m new here I know there is a SMPS schematic on this website but I need the full schematic for the hole machine or a service manual or both for the Camco Audio Vortex 6 PA Amplifier if anyone has a copy can you please upload it I’ve tried asking for it in the wanted section of the website but since someone uploaded just the SMPS now it wont let me ask for the full machine schematic or service manual please help thank you
Yamaha HTR-5630RDS (RX-V340) - védelem lekapcsolja (MEGOLDVA)
Tisztelt Mesterek! A címben szereplő erősítő bekapcsol, és 3 mp múlva ki. (Doksi itt a tanyán van hozzá) A védelmeket service menüből kiiktatva DC PRT 87% üzenettel indul. Eszerint a kimeneti DC védelem aktív, a kimenetek és a GND között 5.5V-ot mérek. Minden kimeneten! A menüben a 10. menüpont első almenüjében DC: 87% PS: 16%. SM szerint DC 7-100 között, PS 27-47 között. A negyedik almenüben IMP 8 PL 255% Itt ír valami treshold feszültségről, de nem értem, pontosan mi lehet. A uC (IC 472) PRI lábán 0V van 1.2 helyett, a PRD lábon pedig 3,96 szintén 1.2 helyett. Mellékelem az STK végfokokon mért feszültségeket. A +12V-os stab elég rendesen melegszik és a rajzon szereplő 12V helyett csak 11.88V. Lehet ennek a túlterhelése a probléma fő oka? De akkor mi vitte el a végfokok feszültségeit ilyen drasztikusan? A méregetések közben sikerült az IC303 5 és 6 lábát rövidre zárnom, minek következtében már nem tudtam kiiktatni a védelmet sw-ből. Ezt az IC-t kivettem és most újra tudok mérni. A feszültség viszonyok nem változtak. Előtte ugyan azokat mértem ezen az IC-n, mint IC302-n. Kérem erősítő javításban nálam jártasabb kollégák segítségét! Szerk: Nem volt minden összeföldelve, így a mérési adatok tévesek voltak. Így már az IC302-n jók a feszültségek. A Center végfokon viszont van némi eltérés. Ezt azért mellékelem. A PRI lábon 0.01V, a PRD lábon 1.38V a mért érték szemben az 1.2V-tal. A diagnosztika menüben kiírt értékek és a tünetek nem változtak. Bocs a hosszáért! u.i.: Ha kiveszem az összes végfokot és R358-R361, R350 (kimeneti ellenállások) "közepére" 0V-ot teszek, a védelemnek elvileg ki kell kapcsolnia nem? Bár elég valószínűtlen, hogy mindhárom STK egyszerre ugyan úgy romoljon el. Lehet, hogy a meghajtó IC romlott el, húzza le a tápot és ad DC-t a bemenetre? Bár a kondis csatolás miatt ez meg nem valószínű... Megoldás: A uC (IC472) 90. lábához vezető fólia hibás. (Valszeg szakadt.) Ezért a DC védelem letiltott. A proc lábát felemeltem és egy darab huzallal D480 katódjára kötöttem.
