Nem nagyon ismerem ezeket,(rajzot nem találtam hozzá) merre induljak el? Tranyók nem zárlatosak, elmondás szerint néha indul. Jól volt bekötve. Kimeneten zárlatot nem mérek.
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Protect modban van mert a kimeneten van DC feszültség, mindkét oldalon megjelenik a + táp (+48V), ha a Left oldalon kiveszem a PNP,NPN végtranzisztor bázis ellenállásait(4R7/0.25W) és csipeszekkel az RCA bemenet GND-jét összekötöm a GND-vel(házzal) akkor a Right oldal 0V, majd a jobb oldal harmadszori bekapcsolas után szintén 0V-ra lecsökken, és a protect mód megszünik.
Ha visszarakom a Left bázis ellenállásait (de a csipeszelés marad) akkor mindkét oldalon -48V jelenik meg, de van néha hogy +48V ra állnak be.
Mérve minden alkatrész jó.Feszültségek a végfokban sehol se jók. Mindenhol +48V vagy -48V van.
Eredetileg az elôerôsítô tápja (+15.8V)-ot elôállító Q133=2SK30 (TO-92) szét volt pukkanva meg a melette levô D109=ZPD16-os tulfeszültség védô zárlatos volt.
Ha kiveszem a Left oldal végtranzisztorait akkor is van a kimeneten +DC feszültség de csak +4V.Na itt megállt a tudomány..
A tápegység típusa:
SONAVOX CANADA 640051 rev:C
A készülékkel egy brüsszeli kollégának gyűlt meg a baja: nem ad tápot az erősítő végfokának.
Rajz nincs. (A gugli csak kezelési utasításokat, és teszteredményeket talált.)
Kimeneti feszültségei ismeretlenek.
Három szubmodult tartalmaz:
660059 számú, amin egy IR2153 dip tokos Half-bridge smps controller található (ez a főtáp kontrollere)
660047 számú, amin egy UA3842A smd tokos Current mode PWM controller található (ez a főtáp szekunder oldalán van, és egy DC-DC konvertert vezérel)
660045 számú, amin egy LNK520PM dip tokos Kis veszteségű CV/CC smps kapcsoló található (ez a stby táp kontrollere)
A végfok (60-70V) tápját DC-DC konverter állítja elő, amit a half-bridge főtáp táplálna, de ez egyáltalán nem indul.
Az áramkör kétoldalas lyuk-galvános nyákon helyezkedik el, de lekövethetetlen a szubmodulok miatt, és nincs is a kezemben, ami ugyebár alapfeltétel lenne ahhoz, hogy kielemezhessem.
Tud ebben segíteni valaki? Rajz, tanács, tapasztalat a javításában?
Csak érdemi válaszokat kérek!
Fülesmester
