BRAUN C2 PCB PRINTS
1.5 MB
Looking for similar braun manual?
    BRAUN C-2 PRINTS C2 PCB
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
KODA AV502 házimozi erősítő
Üdvözöllek benneteket! Adott egy KODA AV502 házimozi erősítő(Serial No.:4M150066)amelynek a koppanásgátló áramköre minden esetben ki-be kapcsolja a hangszórókat, ha a lakásban valamilyen fogyasztó be- vagy kikapcsolódik. Nem rendelkezem semminemű információval ezzel a készülékkel kapcsolatban. A segítségeteket kérem, ha van valakinek szervizinformációja a hibával kapcsolatban -vagy szervizdokumentáció az adott típusra azt megköszönném. Üdv. mpisti
Blaupupnkt Peugeot T1 LOW kód
Üdv kollégák! Hoztak nekem kikódolásra fent emlitett rádiót. A kód kalkulátorok mutatnak olyan számot melyben van "8"-as szám, ezt azonban lehetetlen beütni mert csak 1 és 6 között lehet. Vagy a kalkulátoraim nem jó számot adnak vagy másképp kell ezt megoldani. Tudna e valaki segiteni nekem? A rádió adatai: BP8140X4222072, 7 648 140 392. Előre köszönöm a segitséget. Wlad
SONY CDX L380X
Sziasztok!! Azt szeretném megtudni honnan tudnám letölteni a használati utasítását a szóban forgó autós CD/rádiónak magyarul, mert szinte minden nyelven találtam csak magyarul nem!! Előre is kössz!! Tomi!
