BULOVA 270 AM RADIO RECEIVER SCH
203.8 KB
Looking for similar bulova manual?
BULOVA 270 AM RADIO RECEIVER SCH service manual (1st page)
Preview of BULOVA 270 AM RADIO RECEIVER SCH [1st page]
    BULOVA RADIO RECEIVER 270 AM
Taya DP-510
Az címben szereplő lemezjátszóhoz hangszedő beállító sablont keresek! Nyomtatható változat is érdekel.
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
Orion OBTS-1715 Hordozható erösítő-hangszóró
Hoztak hozzám egy a fenti típusú masinát azzal hogy hamar lemerül az akkumulátora.Valóban nem bírja 10 percnél tovább közepes hangerőnél. Töltés után 14,4 voltot mérek az aku sarkain terhelés nélkül. Ha valakinek van rajz eme gyönyörűséges magyar termékről kérem segítsen ki vele mert nem tudom eldönteni, hogy a töltő vagy az aku rossz.
Üdv. Jenő
Kraus Kpr 100 előerősítő phono bemenet zajos.
Az esetleírásod egy kissé szűkszavú. Javítsd, mert különben törlöm.
