Problem with Denon-Heos-AMP HS1
Cause:
After a factory reset attempt that fails, the following problems occur.
PS
The unit worked just before the factory reset!
Problem:
The device tries to update the firmware automatically (online), but it fails.
The device then flashes red continuously.
According to the service manual, the only option is to load a new factory firmware using a USB dongle.
After many hours of searching the web, I have not been able to find this firmware file.
The service manual refers to an SD (service disk).
The Denon service office does not sell or provide service application software.
I hope for further information/help to solve this problem
Regards Mogens
Sziasztok. A címben szereplő készüléket javítom és elakadtam. A tuner nem szól sztereoban és automata keresés esetén nem találl csatornát csak keres egyfolytában. Ha manuálisan beállítok egy csatornát akkor az szól de csak monóban. Nem vált át sztereora. Az IC1 LA1851 cseréltem de semmi változás. A kissebb kapacitású elkokat is cseréltem de semmi. Táp ic-t is cseréltem. Mi lehet a hiba? Rajzot sajnos nem találtam hozzá. A segítséget előre is köszönöm.
Hello everybody,
This receiver starts normally and has a nice blue display lighting on for 8 seconds. Suddenly you ear the main relay falling down and everything turns off and you get the red led flashing around the main power switch button. There is no special code with this continuous flashing rythm of the led. I have no diagram of the device and I have opened it and measured the voltage on pin 4 of the voltage regulator KIA78R05P1, which has a validating signal on his pin four.(2 is the output and 3 is frame (-)).this 5V(to-220)monolithic 7805 regulator is on the main PCB, close to the little transfo and ON/OFF relay...and is mounted without any heat dissipator(I was surprised of that fact!).the voltage between(4-3)is 1,88V dc and never climbs up during the starting sequence.
Can you help me to solve this problem?
I am looking for a Service and/or User Manual for the Cassette Player DENON DRM-800. English or German please
Thanks in advance
