On 170mm automatic play is ok (after use Start bottom),on 330mm is no arm move.What"s solution?
Phono Denon DP37F no automatic play on 300mm
2017, July 16 - 16:41
#1
Sponsored link
2017, July 16 - 19:23
#351530
Hi radiogaga,
Are you sure, you placed a 300 mm black vinyl record on the platter?
If the outer 33 rpm size recognition opening sees light from the ‘light tower’ (or any other external light), the arm doesn’t move to avoid stylus damage.
Hope it was helpful.
Greetings:
Marcell
2017, July 16 - 20:07
#351532
170 mm play without the vinyl :|
2017, July 17 - 09:54
#351548
This fully automatic turntable gets the information by means of 2 phototransistors receiving light through the small rectangular openings in the rubber mat, which size or if any record lies on the platter.
If you use another mat then the original you fool the automatic.
By the way as I see your English is not very strong, nevertheless you could say Hello, goodbye and thanks.
This is usual here.
Greetings
Marcell
More similar content
