Phono Denon DP37F no automatic play on 300mm
6 posts / 0 new
radiogaga
radiogaga picture
On 170mm automatic play is ok (after use Start bottom),on 330mm is no arm move.What"s solution?
HiFreak
HiFreak picture
Hi radiogaga,
Are you sure, you placed a 300 mm black vinyl record on the platter?
If the outer 33 rpm size recognition opening sees light from the ‘light tower’ (or any other external light), the arm doesn’t move to avoid stylus damage.
Hope it was helpful.
Greetings:
Marcell
radiogaga
radiogaga picture
170 mm play without the vinyl :|
HiFreak
HiFreak picture
This fully automatic turntable gets the information by means of 2 phototransistors receiving light through the small rectangular openings in the rubber mat, which size or if any record lies on the platter.
If you use another mat then the original you fool the automatic.
By the way as I see your English is not very strong, nevertheless you could say Hello, goodbye and thanks.
This is usual here.
Greetings
Marcell
radiogaga
radiogaga picture
THX Marcell:)
I know about pfoto sensors,and mat is orginal,but one diameter works OK,the second is dead.
radiogaga
radiogaga picture
Hi Marcell
In this model of Denon under the plate is any photo sensor.3 sensors are under the arm.What suprise:)
Greetings.
