Hi to all. Unit arrived dead with no power. The problem is with switching power supply. I checked most of the parts, no faulty found. Unable to check PWM ICs. To determine which one has the problem, Service Manual is more than important and necessary. I would appreciate if someone of you can help me find it or send it to me.
Thanks in advance for your kind attention and help.
Regards from Greece,
John
I've done the user Manual reset but it still turns off and standby red led flashes.I,need a service manual and some help to change ac detect fault code.Can anybody assist .
A cím már sokat elárul, és gondolom sokan mondják majd azt hogy NEM!
A helyzet a következő, megkaptam ezt a rettenetet több más készülékkel együtt, hogy villámcsapás érte.
Belenézve megint elment a kedvem mindentől.
Én K.O.-ra gyanakszom, mert bedugva/bekapcsolva semmit nem csinál.
Készenléti trafó megy, 5V körüli feszültség kijön belőle, de semmi több.
Én processzorra gyanakszom, mert egy led sem nyikkan meg rajta...
Érdemes vele tovább foglalkozni?
Üdv,
Krisztián
Problem with Denon-Heos-AMP HS1
Cause:
After a factory reset attempt that fails, the following problems occur.
PS
The unit worked just before the factory reset!
Problem:
The device tries to update the firmware automatically (online), but it fails.
The device then flashes red continuously.
According to the service manual, the only option is to load a new factory firmware using a USB dongle.
After many hours of searching the web, I have not been able to find this firmware file.
The service manual refers to an SD (service disk).
The Denon service office does not sell or provide service application software.
I hope for further information/help to solve this problem
Regards Mogens
