DUCRETET C870--C888 RECEIVER 1938 SCH
235.4 KB
Looking for similar ducretet manual?
DUCRETET C870--C888 RECEIVER 1938 SCH service manual (1st page)
Preview of DUCRETET C870--C888 RECEIVER 1938 SCH [1st page]
    DUCRETET C-870C-888 C870C888 RECEIVER 1938 870 888 C870 C888 C870--C888
JVC TD-W216
Sziasztok Ehhez a deckhez keresek rajzot.Lejátszáskor nem indul a reel motor egyik oldalon semCsévélés rendben van. Köszi a segítséget:B.Laci
Request for Firmware or Help – Kenwood M-9000 SS stuck on "Waiting for PC Wizard"
Hello,
I recently purchased a used Kenwood M-9000 SS micro Hi-Fi system, but unfortunately, the unit is not functioning correctly. When I power it on, the display is stuck on the message "Waiting for PC Wizard", and the device becomes completely unresponsive – it does not react to any buttons or remote control inputs.
From my research, it seems that this issue may be caused by a missing or corrupted firmware, particularly related to the Sunplus SPHE8202 chipset used inside the device.
I have been trying to locate the correct firmware file (possibly DVDROM.BIN) that matches the hardware (the board ID may be BD305890BB9B50), but so far, I have had no luck finding a working download source.
Could someone please help me with:
  • The correct firmware file for this model
  • Instructions or guidance on how to recover the system using a USB flash drive
  • Any experience with solving this "Waiting for PC Wizard" message on similar Sunplus-based systems
Any help or direction would be greatly appreciated!
Thank you in advance.
Best regards,
Dejan Todorović
Aiwa AD-F220 mechanika probléma
Hi!
Tudnátok segíteni?
Hoztak egy ilyet szíjkészlettel, hogy cseréljem ki. Kicseréltem, de nem nagyon akarja tekerni az első orsót, ill. gyors tekerésnél nem maradnak bent az előre hátra csévélő gombok. Mi lehet a bibi?
Kösz
Jelalak probléma , Rockford Fosgate Punch 800.2 , '99 es (PC-2038-B panellel) Megoldva!
Sziasztok! A fent említett erősítő hibás csatornájának hiányzó felső amplitudóját sikerült helyreállítani , viszont azzal a gonddal kűzdöm ,hogy nem szép a jel alakom. Ugye van egy egy potink csatornánként ami ezt hivatott megoldani. Ha betekerem megfelelőre akkor nagyon megnő a nyugalmi áramom a betáp oldalon , terhelés nélkül. A jó oldalnál rendben van a jelalak , be is tudom tekerni , pont úgy viselkedik ahogy kell. A nyugalmi áramom ilyenkor 2A körül mozog , úgy hogy megy mindkét oldal , viszont ha a jelalak rendben van akkor 10A körül mozog ami horror :) Végfoksort kellene cserélnem mert nagy a szivárgóm? Kiegészítem , mert a cím nem adja meg az összes információt , hiába van rajz az oldalon az erősítőröl. Fet-es AB osztály IRF640 , IRF9640 párral . A problémám a két félperiódus illesztésénél keletkező eltolás , ha a munkapontot oda állítom ,hogy szép legyen a jelalak akkor elszabadul az áram ,és természetesen emiatt hőmegfutás is létrejön.
