EICO HF52 SM
4.6 MB
Looking for similar eico manual?
EICO HF52 SM service manual (1st page)
Preview of EICO HF52 SM [1st page]
EICO HF52 SM service manual (2nd page)
Preview of EICO HF52 SM [2nd page]
    EICO HF-52 HF52 HF 52
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Trust erősítő néma Sajnos nincs megoldás (felelet), vége...
 Egy TRUST erősítő (cimke fotója csatolva) néma. 100% táphibás, ennek a rajzát keresném, ha valaki tudna segíteni.  Külső tápról remekül működik, egészen biztos, hogy a kapcs. üzemű tápja a hibás.A FET jó, segítene egy rajz a tápról
Köszönettel :
Kedves kollégák!
Hiába ész, erő, akarat, a sors közbe szólt.
Ma benn volt az ÜF, és azt mondta, hogy ennyit nem áldoz rá. Az "ennyi" egy 5 ezer Ft-os árajánlat volt.
Nem tudom, hogy Ti mennyiért javítottátok volna meg. Lehet, hogy túl drága lettem volna? Ti mennyiért vállaltátok volna?
Mindenesetre köszönet mindenkinek, aki vette a fáradságot, és segített nekem a megoldásban. Sajnálom, hogy mindez hiábavaló volt...
Üdvözlettel:
BMW 630i rádió.
Üdvözletem Mesterek ! Némi segítséget kérnék. Az említett BMW 630i gépből a rádiót szeretném kivenni. Egy robbantott rajz a kiszedéshez igen jól jönne. Nagy navis 2008-s . Valamint egy MUTE szálat keresnék, mivel Trafipax jelzőt és társait építenénk . Ami fontos az azonosításhoz :CV75328. Segítséget előre is megköszönve. Tisztelettel:Öreg T.
Sony MHC-V71 zene ketyere, nem megy a kijelző
Lenne egy ilyen zenedoboz.
Megy rajta minden, a de a kijelző halott.
Innen leszedtem a manualt, de csak blokkséma meg a nyomtatott áramköri rajzok vannak benne.
https://www.manualslib.com/manual/2438663/Sony-Mhc-V71.html?page=2#manual Találkozott már ilyennel valaki? Kösz
