EPW RO PRUF 5 TUBE TESTER TUBE CARDS
METER - SERVICE MANUAL
106.1 KB
METER
Looking for similar epw manual?
EPW RO PRUF 5 TUBE TESTER TUBE CARDS service manual (1st page)
Preview of EPW RO PRUF 5 TUBE TESTER TUBE CARDS [1st page]
EPW RO PRUF 5 TUBE TESTER TUBE CARDS service manual (2nd page)
Preview of EPW RO PRUF 5 TUBE TESTER TUBE CARDS [2nd page]
    EPW RO PRUF TESTER TUBE CARDS
Relevant METER forum topics:
Fluke ScopeMeter 105B Series II Display frozen / no Display
In my case the display of the ScopeMeter was frozen and the keyboard did not respond any more exept the on/off key. This happened always after the ScopeMeter has been switched on for a while. To find the temperature effect, I heated up the different parts of the Digital A1 board with a hair dryer. At some point, the device display stopped working completely and only the backlight was working. This effect was steady and irreversible.
To repair the device, you need the "fluke_92b_96b_99b_105b_servicemanual" provided here in the service manual area.
On page 272 in Figure 9.2b (Digital A1 circuit diagram, part b) the display contrast circuit schematic shows the NPN Transistor V1432 of type BC848C (see also the attached picture). Measuring the Base/Emitter diode showed a low resistance of 100 Ohms in both directions. Replacing that transistor by a NPN transistor of type BC847C solved the problem and the device was working correctly again.
The reason for choosing the BC847C instead of the BC848C are the Vcbo and Vceo of only 30 V of the BC848x series. The BC847x series has a Vcbo of 50 V and a Vceo of 45 V respectively and offers therefore a greater margin. The V1432 is placed between TP431 (LCDPWR, +5 V) and the -30 V connection from Analog Board A2. These conditions are too close to the absolute maximum ratings of the BC848x and are especially for higher temperatures critical.
Előlap fóliák, fóliatasztatúrák, EL fóliák, stb.
üdv: az Elektronline-n találtam. http://www.auter.hu/?elolapfoliak Bálint Ennek inkább a hasznos linkek között a helye.
tektronix 2236 felélesztéshez kérek, keresek segítséget/ MEGOLDVA (T)
A hibajelenség az, hogy ha bekapcsolom hallatszik, hogy a táp elindul, emelkedő frekvenciájú halk sípolás, majd megszűnik és újra kezdi. Előtte a B trigger potméternek (5kohm)csináltam egy tengelyt, mivel tőben el volt törve és ilyen kis potit nem kaptam. Előtte a szkóp 20 éve nem volt bekapcsolva. Szétszedtem, a táprészben a fezsültségek nőnek, majd megszűnnek és ismét nőnek. A DS856 és DS858 glimmek felvillannak mielőtt a táp leállna. A tápben ránézésre minden ép. Mivel nem akarom elrontani jobban, és nincs nagy gyakorlatom, ezért leírom, hogy mit csinálnék és kérek visszajelzés, hogy van e jobb megoldás a hiba behatárolására, illetve találkozott e valaki hasonló hibával. A glimmmeknek (mind a három) égnie kell egyáltalán, ez nem a táp megszaladását jelenti? Leszedtem a 2235-ös rajzát, mivel szerintem a főpanelen a táp szerintem azonos. Mivel el kezdene beindulni a táp ezért szerintem a primer oldalon nem lehet hiba. Vagy igen? Leválasztom a +5, +8,6, +30, +100, -8,6 tápcsatlakozó átkötések megszakításával a terhelést a tápegységről. Megnézem, hogy beindul-e így csak a nagyfeszültségi rész. Ezzel nem okozhatok valami problémát? Ha nem akkor mit és hogyan tovább a nagyfesz részben? Ha beindul megnézem a tápok értékét. Ha a tápok nem jók megnézem, a jelenség alapján arra gondolok, hogy valami beterhel, és ezért az U930 áramkorlátozása életbe lép, szerintem 16 lábon nem lehetne több kb 0,2V-nál. Ha leszabályozza az áram miatt, akkor a szekunder oldalon keresem mi terhelhet be, zárlatos dióda, kondi. Na itt vége a tudományomnak. Esetleg van valaki pesten vagy környékén akihez át tudok menni ezzel és segítene, ha nem járok eredménnyel?
EMG 1566 TR-4650 táphiba?
Segítséget/tanácsot szeretnék kérni egy EMG 1566 szkóppal kapcsolatosan. A szkópot pár éve használom, és néhány hónapja olyan hibát produkál, hogy kis idő elteltével eltűnik a kép, majd hosszabb idő után visszajön. A fényerő sem az igazi. Mi lehet a hiba? Teljes szervízkönyvem meg van hozzá, de még hasonlót sem javítottam, tehát óvatos "duhajként" mernék csak belepiszkálni, ha muszály. Mérni nem szoktam vele, csak jelalak vizsgálatára, hangfrekis erősítők hibakeresésére szoktam használni. Esetleg tudtok ajánlani egy megbízható szerelőt/szervízt? Veszprém megyei vagyok, Pest sajnos "kiesik". Üdv: ljusdr
