Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Van egy HITACHI FT-M1 / HA-M1 SM készülékem ami kb 10 évet pihent a szekrényem alján. Amikor elraktam még működött, de a napokban kivittem a telekre, hogy szóljon ott valami, de a tuner részével valami nem stimmel, mert halott az a része. Csak a tuner része az ami nem működik és ebben szeretném kérni a segítségeteket, hogy kb hol keressem a hibát.
Tibi
A fenti típusú ONKYO rádió-erősítőt javítom.
Eredetileg az egyik végfokozat rossz volt.
Cseréltem a következő alkatrészeket:
Q506 (2SC3421) és Q507 (2SA1358) meghajtó tranzisztorokat,
Q508 (2SC3855) és Q509 (2SA1294) végtranzisztorokat,
Q505 (2SC1815) nyugalmi áram beállító tranzisztort,
R510 (270 ohm) ellenállást valamint a két nagyáramú (2A) biztosítékot.
Megnéztem R507 (10 Kohm) potenciométert kontakthibára, de jónak találtam.
Elindítottam a végfokot és beállítottam a nyugalmi áramot.
Minden rendben volt, elindult hiba nélkül a készülék, járattam kis hangerőn pár wattal.
Már csak a fedlapját kellett volna rátennem amikor egy villanást láttam és elhallgatott.
Mérés alapján a javított végfokozat két végtranzisztora ment teljes rövidzárba valamint megszakadt a két nagyáramú (2A) biztosíték.
A jelenség okát nem tudom, van valami tippetek?
A végfokozat kapcsolási rajzát (TX-7430) mellékeltem.
Kumi
Épp javítok egy ilyen erősítőt.
Tipikus végfokhibával, mert kinyírták.
Ok ezen túl vagyok, működik.
Csak egy dolog ami fura nekem.
A végfok panelon a VT16 (BC327-25) tranyó B-C lábára utólagosan valaki forrasztott egy 22pf-os kondit.
Gyári rajzon nem szerepel.
Ennek mi lehet a szerepe?
Hagyjam vagy leforrasszam?
Korszerűsítés (MOD)!!!
Már túl a 30-on.....
Alapszinten mik azok az alkatrészek amiket érdemes kicserélni, vagy más értékre módosítani?
Amivel esetleg lehetne javítani a minőségen.
Pl a szabályozó modulon, végfokon....stb.
Előre is köszönöm.
